Thread Number: 35327
Electrolux Sidekick: What lube to use? |
Post# 380069   10/21/2017 at 13:22 (2,379 days old) by human (Pines of Carolina)   |   | |
So I recently got hold of an Electrolux Sidekick mini power nozzle as part of a full Electrolux tool kit for my uprights. It seems to work fine except for a slight dry bearing squawk, which seems to be coming from the brush roll instead of the motor. Is there a particular type of lubricant I should use on those bearings? light machine oil? heavy grease? maybe something in between?
Post# 380091 , Reply# 1   10/21/2017 at 20:39 (2,379 days old) by blknblu (CT)   |   | |
I usually use a Teflon based dry lube for that. One advantage, it does not attract dirt as much as a petroleum based lube. There are many different brands, but you should be able to find one easily. |
Post# 380141 , Reply# 2   10/22/2017 at 15:01 (2,378 days old) by human (Pines of Carolina)   |   | |
