Thread Number: 34999
Simplicity Wonder Tandem air Premium unboxing and airflow. |
Post# 377376   8/28/2017 at 17:29 (2,437 days old) by blackheart (North Dakota)   |   | |
I just picked this up today. Initial impression: it's quiet, the nozzle is powerful and produces a good amount of vibration. I'd recommend it for someone looking into a high end canister. There was a little adhesive and fiber stuck to the underside of the machine which is what's under there. The electric hand tool is not included with the vacuum, it was a separate purchase.
Post# 377377 , Reply# 1   8/28/2017 at 17:34 (2,437 days old) by blackheart (North Dakota)   |   | |
Most of it's results were really good. Despite it's long hose it still had very good flow at the end of it. The surprise came at the nozzle. I partially feel like i couldn't get a good seal to the airflow box, i also noticed a lot of leakage when i placed my hand over the hole with the nozzle on top. While it's normal for power nozzles to lose airflow, and often a lot of suction due to do the neck, connections and brushroll ends. I'm surprised to see a loss like this from it. Despite it's nozzle CFM i do feel it cleans very well.
Post# 377383 , Reply# 2   8/28/2017 at 18:09 (2,437 days old) by blackheart (North Dakota)   |   | |
Post# 377384 , Reply# 3   8/28/2017 at 18:10 (2,437 days old) by blackheart (North Dakota)   |   | |
Post# 377445 , Reply# 5   8/29/2017 at 12:17 (2,437 days old) by Wyaple (Pickerington, OH)   |   | |
Post# 377458 , Reply# 7   8/29/2017 at 17:58 (2,436 days old) by blackheart (North Dakota)   |   | |
When i place a Kirby on top of the box i can get a full seal if i put my hand in front of the box's opening the bag will not inflate at all so i feel as though the box is sealed. Part of it could in the lexan panels i use to adjust for smaller nozzles. I've noticed though that when i place any bypass machine on it if i put my hand to the hole there's a significant drop in suction vs measuring it at the wand or hose. I suppose i should get some figures with an upcoming airflow test to demonstrate this. I'm thinking it's from the joints and openings in a nozzle such as the neck, a swivel, any twists or turns in the path, the openings for the roller. I guess I'm unsure if i've shared photos of my box or not.
Regarding it's design. Could it be better sealed so that less flow is lost? I think so. I will say this though pitting the tandem against a Miele Cat and Dog canister the tandem has more agitation as the nozzle approached a line of sand the difference was pretty clear. |
