Thread Number: 34873
Replacing an Electrolux 7000 C153A |
Post# 376359 , Reply# 1   8/4/2017 at 03:15 (2,456 days old) by myles_v (Fredericksburg, VA)   |   | |
Do you mind if I ask what's wrong with the cleaner? Btw, the North American Electrolux company changed their name to Aerus around 2003.
I believe that the Aerus Legacy is the current equivalent, www.aerushome.com/Site/Canisters.... You could expect to spend around $1,000 for a new Legacy from a dealer, or you can find a used machine for a lower price. This website has a number of used/"refurbished" Electrolux/Aerus machines www.greatvacs.com/shop-by... |
Post# 376395 , Reply# 2   8/4/2017 at 13:53 (2,456 days old) by allen (Richlands)   |   | |
I'll try to get back to you about what's wrong with it. My dad knows better than me, and he's been very busy. |
Post# 376635 , Reply# 4   8/10/2017 at 12:48 (2,450 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Allen, yes the Electrolux Epic 6500SR is the same unit. All they did when Electrolux changed their name to Aerus, is change the name to Legacy & replace the double stage Electro Motor they had been making themselves with a single stage Chinese-made Johnson motor. Otherwise, the two machines are exactly identical.
I would strongly suggest before you spend money on ANYTHING that you get your Legacy into a authorized Aerus dealer. Unless you did suck up water, I highly doubt your motor is rusty & needs replacement, it sounds like you just ran into a scam artist that was trying to con you into buying a new vacuum. The fact that your vacuum still turns on & runs, tells me that when you took it apart something got miswired, or a switch might be failing somewhere. Let the people that REALLY know your vacuum have a look at it first. As for compatibility with your attachments, the Epic 6500SR & it's attachments are a exact match. You could also just find a canister only with a rebuilt or new motor installed & just keep what you have & use with the new canister. Any Electrolux plastic bodied canister, EXCEPT the Rennaissance, Epic 8000, Guardian & Guardian Platinum can replace your Legacy, the only differences would be the onboard tool storage being a clip instead of a rack like the 6500SR/Legacy, & some models won't have the Automatic Control bag shutoff feature. Just take a look at the hose end, you will see those units the machine hose end is identical. Best of luck getting your Legacy working again. Rob |
Post# 376716 , Reply# 5   8/12/2017 at 14:18 (2,448 days old) by allen (Richlands)   |   | |
Thanks for that information! |
