Thread Number: 34301
Miele fit for HEB160 |
Post# 371611 , Reply# 1   5/1/2017 at 09:22 (2,551 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
I own the HEB160 already. It will NOT fit a Miele as it is out of the box, it will require some modifications. To make it work, you will need to use a 35mm to 32mm adapter for the powerhead neck, & you will also need to change out the cord as European vacs, like Miele, use a smaller diameter pin on their powerhead cord plugs & receptacles.
Might I ask what you will be using it to clean up? Just so you know, if this is being used on pet hair, the hair will wrap around the brush, & it won't be as easy as some other brands to get in & cut the hair out. There is another electric brush called the Stair Pro that would be better suited for pet hair, as it has a more aggressive brushroll & much easier to clean out; It's a generic version of the Electrolux Sidekick, sold for central vacs & as a aftermarket replacement for Electrolux. Here's a couple links to the parts you will need to convert the HEB160. Rob www.tiptoppartsusa.com/product.ht... www.tiptoppartsusa.com/product.ht... |
Post# 371642 , Reply# 3   5/1/2017 at 20:42 (2,551 days old) by cocobird5 (Laguna Hills)   |   | |
Miele makes one of these too. You might want to see if it would work on your C3 before going to a lot of trouble. |
Post# 371655 , Reply# 4   5/2/2017 at 05:43 (2,550 days old) by DanITman (Michigan)   |   | |
I don't believe MIele makes a mini power head. If you have a link. Please share. Most of the stuff they sell is air driven and not electric. |
Post# 371670 , Reply# 5   5/2/2017 at 12:30 (2,550 days old) by cocobird5 (Laguna Hills)   |   | |
Here is the link to the one I mentioned. I had one and it did a great job. www.achooallergy.com/vacu... |
Post# 371671 , Reply# 6   5/2/2017 at 13:47 (2,550 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
Have not heard of the stair pro, does it have a cord on it or does it use direct connect? I also have the heb160, very nice nozzle, certainly better than any turbo brush. Mike |
