Thread Number: 34199
help with the volt nozzle |
Post# 370627 , Reply# 3   4/13/2017 at 09:05 (2,569 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
I can't see good enough to view pictures, or even read print for that matter, hopefully it will make much more sense once I get it. Mike |
Post# 370629 , Reply# 4   4/13/2017 at 09:19 (2,569 days old) by Kirbysthebest (Midwest)   |   | |
I don't think you will have any problems. You should be able to tactilely orient fairly easily. |
Post# 370638 , Reply# 5   4/13/2017 at 12:13 (2,569 days old) by dysonman1 (the county)   |   | |
The charger that comes with the Volt, plugs directly into the battery pack on the back of the nozzle's handle. There's a small raised circle, if you press it, the green lights will illuminate. Here's a good guide. There are five bars of green. You lose one bar of green for each 15 minutes of run time. From 'dead' to full charge takes approximately one and a half hours. The charger shuts off as soon as battery capacity is reached. After each use, plug it in. If you unplug in one hour, or the next day, it won't hurt the battery and you'll always have full charge.
Enjoy your new Volt. I have a lot of fun running it with vintage canisters, as you will remember from the Vacuum Collectors Convention last year. We plan to do it again this year at the Convention in June at the Vacuum Museum. |
