Thread Number: 33966
comparing wessel werk EBK340 and EBK360 |
Post# 368401   3/14/2017 at 11:09 (2,600 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
So, for anyone who has used both of these nozzles, do you find there is a difference in how well they clean? The 340 does not have a height adjustment like the 360 does, so I would think the 360 would clean better, but for anyone who has used both, would love to know your thoughts. |
Post# 368418 , Reply# 2   3/14/2017 at 16:44 (2,600 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
Wow, I would think with the extra air flow that the volt would clean better than any other nozzle, interesting. |
Post# 368425 , Reply# 3   3/14/2017 at 17:50 (2,600 days old) by ocscott3085 (DMV)   |   | |
The Volt is good but maybe I got a dud? The EBK 360 definitely cleans better in my opinion. |
Post# 368448 , Reply# 4   3/15/2017 at 05:43 (2,599 days old) by Mike811 (Finland)   |   | |
I have EBK 340 and i really like, but I haven't used the 360.
It has almost all the features of the good PH. Surprisingly it also works well on the higher pile dense and soft shag rug. Not too hard to push and pull. However I assume that the 360 is better on that with it's height adjustment. No height adjustment on the 340 is my only gripe and maybe how heavy it is = build quality. Swivel neck is good and no any "safety bars" on the soleplate. Some specs: Wattage - 250W Amperage - 2.0A Motor Manufacturer - AMETEK Italia Circuit Protection - Amperage Sensitive – Manual Reset Breaker Reaction Time - 1 Second Motor RPM (Nominal) - 23,000 Indicator Lights - Green - Normal, Red - Stopped Neck Pivot - 90º Swivel - 180º Release - Pedal Height - 3.25" (82mm) Width - 13.25" (350mm) Weight - 8 Pounds (3.6 Kg) Headlight - Durable / Long Life Fluorescent Wheels – Front - 0.75" (15mm) Dia. X 0.25(5mm) Wide, Back - 2.25" (55mm) Dia. X 1.125(3mm) Wide Brush – Pattern - Double 'V' Chevron Brush – Uninterrupted Width - 12" Brush RPM – Free Float - 8,500 Brush RPM – Plush - 4,600 Brush Bearings - Extra Long Brass Sleeve Bearings Hard Floor Wiper Blade - TPU |
