Thread Number: 33671
DC25 Post Motor Filter Howl |
Post# 366140   2/4/2017 at 19:44 (2,637 days old) by wyaple (Pickerington, OH)   |   | |
Just scored a curb find of my first Dyson ball vac. After a thorough clean up, the machine emits a very loud howling sound when the post motor filter (in the ball) is installed. I meticulously cleaned and dried both filters, so I'm wondering if this sound is normal. When powering down the single pitch howl actually briefly turns into a two note chorus for a few seconds.
To reiterate, this strange (and un-characteristic) noise does not happen if I remove just the post motor filter. Is this filter damaged? I have no issue replacing it, but not if that awful howling is normal. The sound of the DC25 emits is a pretty close match to my DC14 (non-ball) when the post motor filter is removed from the ball. Comments and suggestions welcome, Bill |
Post# 366144 , Reply# 1   2/4/2017 at 20:29 (2,637 days old) by crazykirbydude (Lexington, KY)   |   | |
Post# 366208 , Reply# 3   2/5/2017 at 18:21 (2,636 days old) by wyaple (Pickerington, OH)   |   | |
It is indeed just the post motor filter seal. What happens is that over many years, the seal loses its "springy-ness" and no longer creates a seal with the outer motor housing. My seal isn't cracked or damaged in any way, so this is a wear failure. After Googling, I found this simple solution in pic #2. A piece of string, wedged into the folds of the seal works perfectly! Now my DC25 is quieter than my DC14. All howling gone.
Bill |
Post# 366264 , Reply# 4   2/6/2017 at 15:58 (2,635 days old) by wyaple (Pickerington, OH)   |   | |
Post# 366278 , Reply# 5   2/6/2017 at 18:34 (2,635 days old) by crazykirbydude (Lexington, KY)   |   | |
Post# 366279 , Reply# 6   2/6/2017 at 18:35 (2,635 days old) by crazykirbydude (Lexington, KY)   |   | |
Post# 366294 , Reply# 7   2/6/2017 at 20:39 (2,635 days old) by wyaple (Pickerington, OH)   |   | |
Post# 366298 , Reply# 9   2/6/2017 at 21:34 (2,635 days old) by dustin (Jackson, MI)   |   | |
Every dc25 I've ever used or owned (I've had two and hated them) has done that, it's definitely the seal on the filter. I found if you heat the seal with a hair dryer, then try to push it back into shape, then let it cool down, it seems to help. I think the dc25's are pretty poor vacuums to be honest, good suction from the hose but easily clogged, and very poor carpet cleaning.
Post# 366396 , Reply# 10   2/8/2017 at 21:02 (2,633 days old) by henrydreyfuss (Ohio)   |   | |
