Thread Number: 33653
Suck Factor Over 9000! |
Post# 366155 , Reply# 1   2/4/2017 at 21:28 (2,637 days old) by crazykirbydude (Lexington, KY)   |   | |
Post# 366191 , Reply# 2   2/5/2017 at 12:35 (2,636 days old) by panasonicvac (Northern Utah)   |   | |
Post# 366206 , Reply# 3   2/5/2017 at 18:09 (2,636 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 366303 , Reply# 6   2/7/2017 at 00:59 (2,635 days old) by tolivac (Greenville,NC)   |   | |
Get a Volt Powernozzle to use with your new Imperium CV.You will be glad you did-Will beat ANY other type of powernozzle. |
Post# 366323 , Reply# 7   2/7/2017 at 16:05 (2,634 days old) by ocscott3085 (DMV)   |   | |
I did purchase the Volt and it works fine with my Hide a Hose outlet but I still think the Vacuflo Edge (Wessel-Werk EBK 360) electric powerhead works better. |
Post# 366346 , Reply# 9   2/8/2017 at 04:17 (2,634 days old) by tolivac (Greenville,NC)   |   | |
When I use my Volt with my MD Silentmaster-the Volt beats all of the nozzles I have-Lindhaus,and Sebo.My unit is freestanding-use it with a 35 ft hose in the utility inlet. |
Post# 367615 , Reply# 13   2/27/2017 at 16:50 (2,614 days old) by crazykirbydude (Lexington, KY)   |   | |
My grandparents have an Electrolux SuperLux. It has the SideKick II and most of the attachments, but has clogged numerous times due to them using PVC pipe. I've heard that you're supposed to use special tubing.
P.S. If anyone wants to clean the tubes, there's this thing called Tornado Wipes. You suck one up and it cleans the pipes. www.walmart.com/ip/Tornad... |
Post# 367651 , Reply# 16   2/28/2017 at 09:16 (2,614 days old) by mark40511 (Lexington, KY)   |   | |
had a CV installed when my house was built in 2004. May I ask ?'s for those who own them.
The container that catches the dirt - it's typically located in the garage I assume? Do they leak dust at all into your garage area? Do they use bags or is the container just empty catching the dust, then you have to empty the mess out? I can see how these would be superior in that everything gets sucked out of your environment. I think I would LOVE to have one, unfortunately, my house is already built but if I ever have another house built (which I doubt), this would be definitely something I will do next time. |
Post# 367714 , Reply# 21   3/1/2017 at 21:01 (2,612 days old) by Marks_here (_._)   |   | |
My original Vacuflo 466Q is true cyclonic when I dump it in the woods there is NO dust cloud as people keep saying, no dust anywhere in the garage, on my cars, on the unit or piping even on the vent outside it is clean. It is quiet hence the Q but I did have a muffler on it because my neighbors complained it was too loud when I'd use it at night but I said screw it & took it off let em suffer!!
The Beam Serenety 2725 has a bag filter that is not bad, machine, garage, piping all clean too and this one is very quiet when it's running w/no muffler on it, but there is a dust cloud when I dumped it but the bag does not look like the one in the video, that one should have been replaced years ago. You can tell it was not taken care of & proper maintenance was not performed as mentioned in the handbook. Even though they say no venting is required on some of them I would still do it to make sure the area stays clean & everything goes outside. I have tried to purposely clog mine but the suction us too strong along with the correct piping that was installed in the home long after it was built. I also have a canister separator that attaches to a different hose that you can pick up 4 gallons of water in plus the auction is incredible on it. It is restaurant grade not the smaller plastic ones they have now so if I ever have to pick up water I don't have to hunt for a wet vac. This post was last edited 03/01/2017 at 21:16 |
Post# 367800 , Reply# 23   3/3/2017 at 20:01 (2,610 days old) by vexorgtr (Sheffield, Ohio)   |   | |
Seriously, try one of the Imperiums... QUIET!... Plus major suckage. |
Post# 367805 , Reply# 24   3/3/2017 at 20:52 (2,610 days old) by kenkart ()   |   | |
Want to see something, Mike Hays has 2- 2 motor Beam units in his basement hooked up in tandem to a Sppencer outlet and a full set of Spencer tools...UNBELIEVABLE!! |
