Thread Number: 33177
Pimp My Powernozzle! |
Post# 362320 , Reply# 1   11/12/2016 at 09:53 (2,722 days old) by dysonman1 (the county)   |   | |
Post# 362425 , Reply# 3   11/14/2016 at 16:48 (2,719 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
Perhaps there will be a second generation volt. If the new motor makes that much difference, I think it should be used in the volt as well, even if the run time is shorter. |
Post# 362454 , Reply# 4   11/15/2016 at 03:23 (2,719 days old) by tolivac (Greenville,NC)   |   | |
Will there be a "Volt 2"? Maybe I now have the first one.Will have to see what comes out next! |
Post# 362469 , Reply# 5   11/15/2016 at 13:38 (2,719 days old) by dysonman1 (the county)   |   | |
You do have the first .2 Volt power nozzle. Currently, they do not want to use the more powerful motor in the Volt due to the extremely high suction of some central vacs (like the SilentMaster S5 for example). The dealer can always do a retrofit of the new motor if the customer wants it, but it would work best with a Beam or other lower suction central vac.
Post# 362483 , Reply# 6   11/15/2016 at 22:34 (2,718 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
Kind of makes you wonder if there is a performance difference. With the Freedom, that's the only motor in the system, so you would probably notice a difference, but when you have the suction of a central vacuum, or even a canister vacuum, I wonder if it makes much difference. |
Post# 362487 , Reply# 7   11/16/2016 at 01:06 (2,718 days old) by floor-a-matic (somewhere)   |   | |
what about a mini PN for vacing car ingeriors? My lux sidekick, rainbowmate or wessel werk heb160 dont do too good vacing car carpets |
Post# 362495 , Reply# 8   11/16/2016 at 09:53 (2,718 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
I actually find the wessel-werk heb160 does really well on couches and matresses, I have not tried a side kick or power mate junior. Has anyone tried the volt with a couch or matress? |
Post# 362561 , Reply# 9   11/19/2016 at 03:08 (2,715 days old) by tolivac (Greenville,NC)   |   | |
So far have been using my Pimpted Volt with other vacuums-will try with my MD Silentmaster 15A 120V central vac. |
Post# 362575 , Reply# 10   11/19/2016 at 22:59 (2,714 days old) by Sanitaire (anchorage, alaska)   |   | |
Try the rug rat min turbo cat for stairs, car interiors |
