Thread Number: 33172  /  Tag: 50s/60s/70s Vacuum Cleaners
Electrolux/Hoover
Post# 362289   11/11/2016 at 18:52 (2,722 days old) by Real1shep (Walla Walla, WA)
This seems like an easy query, especially if someone has done this. I'm trying to adapt the end of a Electrolux hose(the metal part that inserts down into the wand), into the wand of a Hoover(Constellation). I bought an 'adapter' off eBay and it's like the male part of the Electrolux hose end x Hoover male w/the locking lug.  Doesn't' get me anywhere except it fits/locks to the Hoover wand.
Now the other way around;using the Constellation hose end with a Electrolux wand would work if one half of this tool was much longer to fit all the way down the Electrolux wand.
Somebody?
Kevin
Post# 362291 , Reply# 1   11/11/2016 at 20:25 (2,722 days old) by adam-aussie-vac ( Canberra, Australia )
adam-aussie-vac's profile picture
do you havw a picture of it?
Post# 362319 , Reply# 2   11/12/2016 at 09:49 (2,722 days old) by dysonman1 (the county)
Hoover made a wand for their power nozzle (to be used with central vacuum hoses) that fit the Hoover neck but the other end fit a 1 1/4 inch standard hose end. If you get one of those wands, you'll be good to go.
Post# 362339 , Reply# 3   11/12/2016 at 15:42 (2,721 days old) by Real1shep (Walla Walla, WA)
Thanks! I'll look for that then....do they turn up on eBay ever?
If this adapter is ABS, I can glue a length on to fit way down into the Electrolux wand. That will take me to one conversion anyway. I'll post a pic of it later...the adapter as bought on the bay.
*Update:OK, here is a pic of what I bought. As I said, if I made one side appreciably longer, it would work with going from the Hoover hose end to the Electrolux wands. I also want to go from the Electrolux hose end to the Hoover wand as well, which will require a different configuration...male x female.
What started this was......that floor head that came with the later model Constellation(not the reissue model) does a really great job with the dog hair on the hard floors. The Electrolux floor brushes don't really have any edge cleaning side ports, so it tends to push & capture what it can....you have to repeatedly raise and lower the floor brush for best effect. That Hoover head gets it all one pass.  So I thought with the superior suction and air flow of the Diamond J with that Hoover floor head, it should be unstoppable floor cleaning in my situation.
Kevin
This post was last edited 11/12/2016 at 16:15
