Thread Number: 33052
Who Has Used All Four Of The Newest Kirby Brushrolls? |
Post# 361157   10/19/2016 at 11:38 (2,745 days old) by wyaple (Pickerington, OH)   |   | |
And opinions/observations on all of them...
Here's a list I believe to be comprehensive for the G5 and up machines: Part#-----Description--------Appearance 152505---stiff bristles--------oblique tight tufts 152502---medium bristles---oblique loose tufts 156197---pet owners---------oblique white tufts 159398---delicate bristles---chevron white tufts To date, I have only used the top two. I know that 152505 seems to be the standard brushroll and while I like it's performance, it seems too rough on standard carpet and far too rough on anything considered to be delicate. When I look in the bag, I see more loose carpet threads by volume than actual dirt. When I use 152502 (or 156294 for my G4), I get more dirt and much less loose fibers. Since my carpet is "squeaky" clean, I figure why remove more carpet than necessary? I have not tried the softer two options to date, but I have to wonder, are they too soft? What will they actually pick up? Bill |
Post# 361200 , Reply# 2   10/20/2016 at 08:48 (2,744 days old) by suckolux (Yuba City, CA)   |   | |
Post# 361222 , Reply# 3   10/20/2016 at 16:03 (2,744 days old) by brycerivers (Atlanta,GA,30273,United States)   |   | |
You Can Change the brushroll end caps. I discovered this recently a month ago when I ordered A brushroll for My Ultimate G, I ended up getting a g3 brushroll and was able to pop off the end caps and switch them around. If you was to get a newer style roll just pop off the end caps and re-arrange them for the BPI.
Post# 361226 , Reply# 4   10/20/2016 at 17:03 (2,744 days old) by sptyks (Skowhegan, Maine)   |   | |
Is too easy and not a good idea!
Now your BPI is working, But your brushroll is running in REVERSE! By swapping the brushroll end over end it is running in the other direction. Why does this make a difference, you ask?
Take a look at the oblique pattern of the brushes. They are now pushing the dirt away from the center fan intake instead of toward it!
The brushes are now trying to move the dirt toward the sides of the nozzle.
Sorry to burst your bubble, but someone else already tried this years ago. You can search the archives for it.
This post was last edited 10/20/2016 at 19:56 |
Post# 361584 , Reply# 5   10/28/2016 at 00:00 (2,736 days old) by S2_82 (Ohio)   |   | |
I wont mess with it then. Thanks for the info :) |
Post# 361619 , Reply# 6   10/28/2016 at 20:20 (2,736 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
If you want to try the 152505 brushroll for the Kirby Sentria & Avalir, what you could do is find a good used powerhead for a G5 or later Kirby from a Kirby dealer, local vac shop or Ebay. Sure, the cosmetics would be different, but assuming this is a "daily driver", who cares? As long as it works!
Having said that, I would try putting your brushroll in the 3rd wear position first & see if you find that improves the grooming performance of the G3 powerhead to your satisfaction. I found that doing that made a world of difference with my G4. If you still want to try the Sentria & Avalir brushroll, I would see if you can get your hands on a newer Kirby that has that brushroll to try it out first. I wouldn't be surprised if you still had to put the brushroll on setting 2 or 3 to get decent grooming performance. Admittedly, that's the reason my Kirby's are for show now & why I prefer newer Royal Metal uprights as a "daily driver", the beater bar brushroll on the Royal is FAR superior to Kirby's. As for why Kirby wouldn't make this brushroll for the G3 & G4? So that you might be encouraged to retire it & get a new Kirby with the improved features & performance. Rob |
Post# 361697 , Reply# 8   10/30/2016 at 12:04 (2,734 days old) by sptyks (Skowhegan, Maine)   |   | |
I have a Sentria that I replaced the brushroll in a few months ago. I installed the newer stiff brushroll set at setting #1 and it grooms my carpet very well.
I have noticed the grooming is best right after the bag has been replaced. The extra airflow with a new bag pulls the carpet tighter up against the rug plate allowing the brushes to better contact the carpet. The grooming effect decreases as the bag fills up. |
