Thread Number: 32820
Help with Hoover 612 |
Post# 359308   9/14/2016 at 17:13 (2,780 days old) by adam-aussie-vac ( Canberra, Australia )   |   | |
I need help with my Hoover 612, the fan is loose and the nut is tight, am I missing a spacer or spacers?
And what voltage does the bulb run off? |
Post# 359329 , Reply# 2   9/15/2016 at 02:48 (2,780 days old) by aussie-plugs (Melbourne, Australia)   |   | |
The bulb runs off AU mains voltage - 220V/240V. You can still get small pilot lamps at hardware stores that will suit. 25W max SBC should do it. If old bulb is in machine, take it to the shop and look for similar. Good luck. Original bag looks great! |
Post# 359330 , Reply# 3   9/15/2016 at 03:26 (2,780 days old) by adam-aussie-vac ( Canberra, Australia )   |   | |
Post# 359333 , Reply# 4   9/15/2016 at 05:04 (2,780 days old) by Vintagerepairer (England)   |   | |
On the internet I suppose. |
Post# 359334 , Reply# 5   9/15/2016 at 05:37 (2,780 days old) by Nate94 (Sydney, Australia)   |   | |
Amazon sell fairly cheap belts suited for that machine. Nate94 |
Post# 359335 , Reply# 6   9/15/2016 at 07:18 (2,780 days old) by adam-aussie-vac ( Canberra, Australia )   |   | |
I am going to try the local Godfreys superstore and vacuum shops
I got one belt from Godfreys but that was for my Hoover senior ( in the picture )
Post# 359431 , Reply# 7   9/16/2016 at 17:19 (2,778 days old) by Vintagerepairer (England)   |   | |
Ah yes I forgot that the 612 belt is bigger. This said, in all my years repairing cleaners I swore that a Junior belt on a Senior and a Senior belt on a 612 style machine always worked better and without any damage. |
Post# 359494 , Reply# 8   9/18/2016 at 00:46 (2,777 days old) by adam-aussie-vac ( Canberra, Australia )   |   | |
Post# 359495 , Reply# 9   9/18/2016 at 00:50 (2,777 days old) by adam-aussie-vac ( Canberra, Australia )   |   | |
Post# 359502 , Reply# 10   9/18/2016 at 17:29 (2,776 days old) by Vintagerepairer (England)   |   | |
Yes, you need to hold the armature securely and unbolt the pulley by turning it clockwise. |
Post# 359527 , Reply# 11   9/19/2016 at 04:18 (2,776 days old) by adam-aussie-vac ( Canberra, Australia )   |   | |
Post# 359610 , Reply# 12   9/19/2016 at 20:58 (2,775 days old) by chad (texas)   |   | |
Don't know if they-re the same regarding this, but on my 825 the armature is slotted on the bottom for a flat screwdriver to hold it. |
Post# 359623 , Reply# 13   9/20/2016 at 05:24 (2,775 days old) by adam-aussie-vac ( Canberra, Australia )   |   | |
