Thread Number: 32733
Royal 4000 light bulb issue |
Post# 358659 , Reply# 1   9/3/2016 at 11:33 (2,792 days old) by human (Pines of Carolina)   |   | |
I have no direct knowledge about this model but there are two things worth checking:
1. Do the positions of the contacts on the bulb match those on the socket? If not, you may have the wrong bulb. 2. Have you checked for broken wires? It's entirely possible that there could be a design flaw with that model that causes the wires to fail. If you can access the headlight socket while the machine is pugged in and turned on, you may want to test it with a voltmeter to see if the socket is receiving current. |
