Thread Number: 32338
Eureka and Kenmore history |
Post# 355559 , Reply# 3   7/7/2016 at 10:44 (2,861 days old) by kirbyvertibles (Independence, KS)   |   | |
Hans was referring to the Canister vacs. Those earlier ones are referred to as tanks.
I don't know much about the pre power nozzle Eureka canisters but in 1972 Eureka introduced a new line of canisters (3 models) with Eureka's first power nozzle. The sage green and off white colored canned ham was top of the line, the orange and white square body with power selector was mid range and the harvest gold and white was budget. All 3 power nozzles were the same woodgrain no headlight. In 1974 the added the power nozzle to their very popular small square canister called the princess. It was an all red canister with a matching red power nozzle with black label. Also in 1974 they added a head light to power nozzle for their higher end canisters. all of these canisters model numbers all started with a 1200 series number. In 1976 or 78 they made a few slight changes in the power nozzle like bigger plug, bottom plate now has screws VS snap tabs, and a plastic neck instead of plastic, and built in cord holders on the wands. During this time they also introduced a new line of canisters. Still basically the same as before but with a color change and added metal brush roll (VG1) to the top of the line. These were all a burgundy glossy color called the Brandywine line. This line also had a canned ham model. These power nozzles while the exact same as before now sporting a pretty glossy brandywine label. Sometime in the early 80s they made a new line with model number series changing from 1200 to 1700 series and with that came the VGII brushroll. There were many many many models from 1972- about 1992. Some of the very last ones are the all white and all black and all orangeish red models called the ironside and quiet kleen and vactronic. If you run across any of these with a 3 digit model number starting with a 6 that means they were K-mart exclusives. |
Post# 355584 , Reply# 5   7/7/2016 at 16:27 (2,861 days old) by fan-of-fans (USA)   |   | |
I don't know much about Kenmore canisters and even less about Eureka, but I will try to give a little info.
In the early 70s the Kenmore canisters had a metal base and metal top. The Sears Best model had a two speed toggle switch and performance light on top. It also had an opening in the front of the lid where the attachments could be stored. The lesser models had pegs on top to hold them. Colors were avocado/white and a bluish gray/white. In 1972 the all plastic square versions came out. The TOL again was Sears Best and had a two speed slide switch and performance light on top. The lid had woodgrain trim on the top and opening it there was a tool caddy that could sit on top of the bag or attach to the top of the lid when in use. The lower end models usually had a separate compartment for the tools and some had woodgrain with lower ones having none. 1972-77 models were avocado green/yellow. Late 1977 I think was when they changed to two tone blue. 1979 was beige with orange bumpers. As far as bags, the 1972 and newer full size canisters use 5023/5033 bags which are still available at Sears (at least here) as type E. They are getting a little harder to find I think, no HEPA version exists that I know of, but some other bags for newer machines will fit. The older canisters use a different bag number that I can't recall at the moment. It's smaller, and is no longer available from Sears or aftermarket as far as I know. It appears that a Type E bag may fit though, the connection looks the same to me anyway. The 1984 and newer models with the swivel hose use 5055 which are still readily available as Type C paper or Q HEPA bags as those are what the new ones still use (at least until Panasonic discontinues making them). We shall see what Cleva decides to do on their new models for bags. |
