Thread Number: 31894  /  Tag: 80s/90s Vacuum Cleaners
Electrolux Epic 6500 SR wiring diagram
Post# 351616   5/5/2016 at 12:51 (2,912 days old) by ncpapaul ()
Hello and thank you all for allowing me to join. My wife decided to vacuum a pile of small gravel that got all scattered in our 6500 SR. I took it all apart to clean it up and lost track of the white and black wires, some doubled wires. I marked the motor case "black" or "2whites" or "3black" but I did not mark the wires. Does anyone have a diagram for this one? Thank you, Paul
Post# 351638 , Reply# 1   5/5/2016 at 15:43 (2,912 days old) by blknblu (CT)
It is somewhat similat to the Electrolux 2100 series plastic canisters
Take a look at this diagram, which was recently redone in the last few months:
Electrolux 2100 Vacuum Diagram
blog.evacuumstore.com/post/2016/0...
I have a diagram I updated myself for the 2100 series if interested.
Post# 351670 , Reply# 2   5/5/2016 at 22:25 (2,912 days old) by blknblu (CT)
wiring is easy once you know what you are looking at.
The motor cover should have an indentation near the terminal.
This marks the separation between the "hot" and "neutral" circuits.
 In simple terms:
Bag door:
The bag door wires should have one side going to "hot", and the other to "neutral". These will usually be piggybacked onto another terminal.
bag lockout & power switch:
These wires go the neutral/white side only.
for the ones with the controls on top
wire for bag check light goes to neutral, wire for overheat light goes to hot.
My pics are for a basic 2100. Look at the diagram from evacuumstore for reference
Post# 351714 , Reply# 3   5/6/2016 at 16:18 (2,911 days old) by ncpapaul ()
Wiring replies
Thank you greatly, I'll get on it soon and report back.
Post# 351962 , Reply# 4   5/10/2016 at 21:49 (2,907 days old) by blknblu (CT)
Found this in an older thread. Posting it for future requests.
www.vacuumland.org/cgi-bin/TD/TD-...
