Thread Number: 31805
Hoover Caddy Vac Soft Bristle Brushroll |
Post# 351131 , Reply# 1   4/27/2016 at 20:49 (2,920 days old) by Durango159 (State College, PA)   |   | |
Originally when the Caddy Vac hit the market the bristles were a stiff light colored blue.
The Caddy Vac will do just fine to replace it with a standard stiffer 48414081 brush roll! The 48414081 brush is the same fit as that as Hoover Elite uprights, Hoover Futura and PowerMax canisters they all have the same compatible brush roll. Hoover just made machines with variable brush rolls. I remember seeing when the TurboPower 2000 Caddy Vac came out with the green softer brush roll. It was a shock because prior version Caddy Vac 3700 TurboPower had the stiffer blue colored brush roll. There is a white colored bristle one that is an acrylic brush roll and a groove visible in the brush roll. I would go with that one! Don't get the all black CWP, it won't work good as you'd like. Also to use a Type Y bag you're probably folding in some of the top and bottom section of the bag. A Type Z will do you just fine. Though there is a HEPA similar cloth bag set up in green packaging made by Envirocare and those are sized as Y but would would very well in your Hoover Caddy Vac! |
