Thread Number: 31578
Royal 9700 versus Royal 1020z |
Post# 349064   3/30/2016 at 12:11 (2,949 days old) by william (Philadelphia)   |   | |
Can anyone tell me the main differences of these two models from the 90's? Which one is preferable for standard home cleaning? Looking for some opinions on these Royals! Thanks! Bill |
Post# 349071 , Reply# 1   3/30/2016 at 12:59 (2,949 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Bill,
The 9700 was a "master-class" (hence being a part of the "Preferred" ensemble) equivalent of the model 994/996 household upright produced from 1990-1995, and had a 7 amp (non drop in) motor. Later examples had a BPI (brush roll performance indicator) light which showed if the brush roll and belt were functioning properly, so make sure the brush roll in it is correct. The 1020(Z) was a heavy duty commercial upright produced from 1995-2002, and had a 10 amp drop in "screamer" motor. It replaced the 670(Z) which like the 9700 had used the 7 amp (non drop in) motor. Some 1020s had a shake-out bag on them; these of course lacked the "Z" suffix ("Z" = zipper denim bag for disposable paper bags). Both machines used brush rolls with double bristles and stiffeners. ~Ben |
Post# 349092 , Reply# 4   3/30/2016 at 14:29 (2,948 days old) by william (Philadelphia)   |   | |
Post# 349101 , Reply# 5   3/30/2016 at 15:52 (2,948 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Bill,
Yes, I would like to see you purchase that 9700 because of how rare that first-year model is. The one you found was made in July 1990. Back then, it looked similar to the model 9089. The only problem might be with the brush roll if it requires replacement, since the old-style square-end brush rolls have been deleted from TTI's inventory recently. ~Ben
Post# 349113 , Reply# 6   3/30/2016 at 17:52 (2,948 days old) by william (Philadelphia)   |   | |
Thank you Ben for your support and helpful insights. I learn alot. I will let you know if I get it. Bill |
Post# 349115 , Reply# 7   3/30/2016 at 18:25 (2,948 days old) by william (Philadelphia)   |   | |
Ben, Would the link below contain the right replacement brush rolls for the 9700? Bill CLICK HERE TO GO TO william's LINK on eBay |
Post# 349116 , Reply# 8   3/30/2016 at 18:41 (2,948 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 349154 , Reply# 9   3/31/2016 at 10:08 (2,948 days old) by william (Philadelphia)   |   | |
Ben, I bought the 9700. Hoping my newly acquired unit has the 9 blade. Do you think it does with the July date of 1990? Is there any way to tell without breaking it down? Bill |
Post# 349175 , Reply# 10   3/31/2016 at 13:01 (2,948 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Bill,
Yes - all 9700s will have nine-blade impeller fans. The way it attaches to the armature is different than with all the pre-1990 Royals: it slips on rather than being screwed on in reverse. This is what your 9700 would sound like: BTW, good luck on finding an original outer bag for this machine! The model 4000 and 4008 (both of them pre-2002) have the same bag. ~Ben This post was last edited 03/31/2016 at 15:25 |
Post# 349187 , Reply# 11   3/31/2016 at 14:51 (2,947 days old) by sptyks (Skowhegan, Maine)   |   | |
Bill,
You may also enjoy this video of a royal 9700 kicking a brand new Dyson's butt:
Post# 349266 , Reply# 13   4/1/2016 at 15:30 (2,946 days old) by sptyks (Skowhegan, Maine)   |   | |
The BPI indicator light is not a light bulb, but a green colored LED which should never burn out! So if it doesn't light, there are several possibilities:
1. The Brushroll is not spinning because the belt is not properly engaged. 2. The Brushroll is not spinning because the belt is broken or missing. 3.The Brushroll is installed backward. 4. The Brushroll is the wrong one for the 9700. It may not have a magnet imbedded into the wood at one end. The magnet is what energizes the BPI light. AS the brushroll spins the magnet passes very closely to a tightly wound coil of wire on each revolution. This induces a small current in the coil which lights the LED. 5. If the brushroll bearings are imbedded with hair and dirt/crud, the brushroll may not reach full speed of approx. 3900 RPM. If not, the BPI will blink rapidly. I have seen brushrolls so clogged up with hair and gunk, that they are completely seized and won't spin at all.
Here is a very good video of how to replace the Belt and Brushroll on your Royal:
