Thread Number: 31351  /  Tag: Recent Vacuum Cleaners from past 20 years
116 Kenmore / Panasonic interchangeability - parts tip
Post# 346753   3/8/2016 at 14:48 (2,970 days old) by blknblu (CT)
Some of you may know this, but there is a way to interchange part numbers between the Kenmore 116 vacs & the Panasonic. The Kenmore vacs with a prefix of 116 are made by Panasonic.
Kenmore Panasonic parts have a prefix of K, and Panasonic - A, do some research, and you will find you have more options to get parts. Also, try dropping the prefix when looking.
Example: Kenmore motor KC92FDJHZ000 is the same as a Panasonic AC92FDJHZ000, and the motor may be marked C92FDJHZ000
Post# 346777 , Reply# 1   3/8/2016 at 19:48 (2,970 days old) by n0oxy (Saint Louis Missouri, United States)
interchanging Panasonic and Kenmore parts
I actually have a Panasonic Mc-cg902, which is a very good canister for the price. It came with a paper bag, but I was told by a member here to get some of the Kenmore q bags, they are cloth instead of paper and would work better. Sure enough, they do and they fit that vacuum perfectly. Not sure if the Q bags are used in any current models or if they just sell them for older models now, but they are good bags if your vacuum can use them.
Post# 346784 , Reply# 2   3/8/2016 at 20:06 (2,970 days old) by blknblu (CT)
I have (had) two Kenmore 116 models, a Progressive and and Intuition.
Both are one of the poorest designed vacuums I have seen, and the Centec derived power nozzles are the worst.
The front axles on the power nozzle always pop off, since it is just a rod bent into a "C" with small wheels on it, and a small plastic "lifter" to raise and lower it. Both of the ones I received had them duct taped down.
A power nozzle should be sturdy and these are not. You do not see many plastic pieces for the 116 Kenmore's on ebay for a reason, they break too readily. I received both of them free, since the owners were frustrated with them. (Broken parts & pieces)
Post# 346806 , Reply# 3   3/8/2016 at 23:02 (2,970 days old) by kenkart ()
Re 116 prefix..
The prefix 116 indicated Birtman Electric Company until 1957 when Whirlpool took over Birtman,It was Whirlpool for many years, Panasonic came much later.
