Thread Number: 31021
1.6 Kenmore Filters??? |
Post# 342840 , Reply# 1   2/4/2016 at 14:40 (3,004 days old) by Compactc9guy (Bathurst NB)   |   | |
Post# 342981 , Reply# 2   2/6/2016 at 12:45 (3,002 days old) by fan-of-fans (USA)   |   | |
Post# 343068 , Reply# 3   2/7/2016 at 09:16 (3,001 days old) by blknblu (CT)   |   | |
Sears PartsDirect no longer has them. This pic shows the part numbers they show for it.
Post# 343070 , Reply# 4   2/7/2016 at 09:45 (3,001 days old) by mchmike (West palm beach fl)   |   | |
You can make one using air conditioner filter material from Home Depot . |
Post# 343075 , Reply# 5   2/7/2016 at 11:07 (3,001 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Sorry to have to say this, but I think your best solution to your filter dilemma is to sell the vacuum on Ebay, Craigslist or Kijiji as a parts machine & get rid of it. Unfortunately, Sanyo was bought by Panasonic in 2010 & slowly phased out most of their models & parts. This canister would be one of them & parts are NLA.
As for Mchmike's suggestion to try making a new filter, the problem with that is, as seen in the diagram above, the filter is encased in a plastic frame, with a screen covering it. It would be VERY difficult to find a glue that would hold air conditioner pleated filter media in place for a long period of time & it be a lasting repair. Further, the pleated filters that come in bagless vacuums are usually sprayed with a coating of some sort, perhaps Teflon or a plastic polymer of some sort, that makes the filter paper resistant to water, which makes it so you can wash & renew the filter when banging. Unless you can replicate that compound the filter is sprayed with at the factory, the air conditioner pleated filter media will clog very quickly after a few uses....remember, this pleated filter material was designed to be used in a air conditioner or furnace for 2 to 3 months, then thrown away & replaced, to be disposable. Also, in a vacuum cleaner, it is going to be exposed to A LOT more dust, & much more quickly, than if it was installed in a furnace or air conditioner. Even if you try vacuuming it off, that won't fully renew it's performance, & washing it will cause it to disintegrate, which means you have to glue another filter in place. That will get old quickly! What I would suggest you do is get your wife this Panasonic canister to replace the Sanyo. It is very similar to the Sanyo....bagless with a pleated filter, straight suction with a long tube & attachments. There is also a Kenmore version of the vacuum, but it shows it as having a turbo brush, so the Panasonic might be better for you if you are using it for bare floors & attachment use. It also might be a good idea to contact a few old-time vac shops in your area, & keep an eye on Ebay. You might eventually find a filter somewhere & put the Sanyo back into service. Rob CLICK HERE TO GO TO kirbylux77's LINK |
Post# 343077 , Reply# 6   2/7/2016 at 11:19 (3,001 days old) by mchmike (West palm beach fl)   |   | |
Not the central air style material . The window unit material . It can be made slightly larger than the original piece and pressure can keep it in place . It can also be replaced as needed. ( eyes crossing and rolling ) |
