Thread Number: 30011
Spec's for AEG AG71A |
Post# 333618 , Reply# 1   9/10/2015 at 03:39 (3,151 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Hi mdm, the AEG was previously sold in the UK under the Electrolux Z61A Corded Handheld/Stair Vacuum Cleaner. It is available at John Lewis and others under the AEG AG71A title. What KIND of detailed spec are you looking for that you can't seem to find? I know some of the other UK members on here have the Electrolux/AEG model, but in in the U.S it is also sold under the name of Eureka 71B
If looking for a hand held with a motorised brush roll, second hand Dirt Devil Handy vacs are great but they don't have a built in hose. It's forte is a brush roll and easy enough weight. Takes a bag but has a soft bag on the rear end can be used bagless (but its messy). Then there's the Hometek Hunter, or Dirt Devil 1000 DHC004 - I had one of those - they're slightly more modern as they have a hose on the back of them, but its a roasting hand kind of an experience and the filter clogs up a lot, being a basic paper pleated cone/single cone bagless job. (Stock photo shown from Amazon UK) By the way, what vacuum cleaner do you normally have? Personally if it was me, I'd buy a small cheap bagged cylinder vac with a long hose, and just use that provided it has tools on board I can use. But if it is for stair cleaning only, either a hand held mains corded vac like the AEG or Dirt Devils or an air driven turbo brush for the vacuum I already own.
Post# 333624 , Reply# 4   9/10/2015 at 07:31 (3,151 days old) by eurekaprince (Montreal, Canada)   |   | |
The AEG you refer to is a Eureka EasyClean in North America. It is a highly rated hand vac in our Consumer Reports tests. See the link below...
Post# 333625 , Reply# 5   9/10/2015 at 07:34 (3,151 days old) by Turbomaster1984 (Ripley, Derbyshire)   |   | |
MDM
Can you explain a little about your cicumstances before we give any advice? You ask for suction power but what exactly are you sucking up? Is it bcause you have pets and you want pet hair removal from stairs and upholstery that requires more agressive agitation? OR do you just have normal non lint dirt that can be gotten up just by suction? What sort of attachments are you likely to use or do you just plan on using the main cleaner even if it restricts access or ease of use? Will the use of a hose be good - one attached to the cleaner for getting between awkward gaps and in restricted space? Theres so many chocies out there and very good ones that its important to know what your needs are before advice is given. Rob |
Post# 333636 , Reply# 6   9/10/2015 at 11:09 (3,151 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Post# 334025 , Reply# 7   9/15/2015 at 22:41 (3,145 days old) by eurekaprince (Montreal, Canada)   |   | |
