Thread Number: 29889
The Royal-Lux Formerly Known as the Royal-Electro! |
Post# 332540   8/25/2015 at 19:41 (3,178 days old) by electrolux137 (Los Angeles)   |   | |
~ Y'all may recall that a while back -- in fact, a year ago almost to the day -- I gussied up a Royal canister machine that I had found in the junk pile of a local vac shop. The Royal did not come with anything but a non-functioning power nozzle and mismatched dusting attachments, so I adapted a spare set of Kirby Legend II wands and floor nozzles. (They proved to be too light-weight for that long hose and they flopped all over the place and I didn't like them.) I also installed a beautiful chrome-plated cord winder from an older Royal that I had found on eBay a long time ago. It was a brand-new OEM replacement that I got for just a couple of bucks and I was finally able to put it to use. For the next round of vivesection, I removed the ugly and ungainly tool caddy that it came with. (To me, it made that sleek machine look like it had a beer belly!) I kept the original extra-long maroon hose but grafted an Electrolux handle onto it. I removed the power nozzle hardware and pigtail connector from the machine-end coupler since I didn't plan to ever use it with a power nozzle. Finally, I outfitted it with a set of Electrolux aluminum wands and white Electrolux combination attachments. I was thinking right from the get-go that dark-gray attachments would look better with the maroon color of the machine, so I began looking for them. Plus, I didn't really like the original hose. It was just too long. I knew that the dark gray combination attachments from the Aerus Lux Platinum would look nice, but the cost for new ones is ridiculously high. So I started going around and asking folks if they had any spares I could get for a bit lower than a new set, and one at a time the attachments came to me at very reasonable prices. The last thing I found, purely by luck in a bunch of other stuff another vacuum cleaner collector gave me, was a Kirby G4 hose. I've seen two different styles of G4 hoses, one dark-gray with matching dark-gray connectors, and one lighter-gray with dark-gray connectors. I don't know which came first but I had gotten both of them, and the all-dark-gray one matched the other "new Royal" accessories the best. Attaching the machine end of the hose to the coupler was just a piece of cake, and I liked how I was able to eliminate the large and bulky casing for the power nozzle wiring that I thought was just plain ugly. So here you have it, in all its radiant glory ... the ROYAL-LUX! I changed the name to Royal-Lux rather than my original name Electro-Royal, because Electro-Royal sounds too much like Electro-Hygiene. "Just Another Day in Sweeper Paradise..." |
Post# 332554 , Reply# 1   8/25/2015 at 22:10 (3,178 days old) by suckolux (Yuba City, CA)   |   | |
Post# 332556 , Reply# 2   8/25/2015 at 22:18 (3,178 days old) by charleskirby66 (Manteca, CA)   |   | |
Post# 332559 , Reply# 4   8/25/2015 at 23:22 (3,178 days old) by stricklybojack (Southern California)   |   | |
Post# 332673 , Reply# 6   8/28/2015 at 06:37 (3,176 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
If you want to remove the hose from the hose connector to attach a new hose to it, use a hair dryer. Put the hair dryer on the end & let it take at least 5 minutes, & make sure the heat gets all around the hose cuff. You will find this will soften the rubber & melt the glue inside. It's then simply a matter of using your muscles & a old flat blade screwdriver & giving a good hard pull to remove the hose connector from the hose.
Hope this helps you out. Rob |
