Thread Number: 28347
Direct air motor vs Clean air motors |
Post# 316598 , Reply# 1   2/24/2015 at 05:31 (3,348 days old) by turbomaster1984 (Ripley, Derbyshire)   |   | |
Post# 316599 , Reply# 2   2/24/2015 at 05:39 (3,348 days old) by marcusprit ()   |   | |
I do know that the CRI give Kirby a Gold award but they haven't tested Miele. Sebo get a Bronze award. Would be interesting if anyone knows what the difference in percentage is? |
Post# 316604 , Reply# 3   2/24/2015 at 07:42 (3,348 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Post# 316612 , Reply# 6   2/24/2015 at 09:34 (3,348 days old) by floor-a-matic (somewhere)   |   | |
Check your local garage/yard sales, curbsides or thrift stores & pawn shops; U might find a Kirby there |
Post# 316613 , Reply# 7   2/24/2015 at 09:39 (3,348 days old) by marcusprit ()   |   | |
I do have a friend who has a Ultimate G I'll see if I can borrow it for a weekend. |
Post# 316614 , Reply# 8   2/24/2015 at 09:45 (3,348 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
"...using an empty vacuum with new filters, vacuum the carpet square in a fixed number of strokes in a fixed pattern and weigh how much each vacuum sucks out...."
Yes, but make sure you clean the brush roll off first, otherwise whatever is on it before hand may be dislodged by the test material you are picking up, not to just mention that but also the dust channel, the dust hose channel and anything else inside the vacuum that will surely deter the transparency of the test given that sand or grit etc can dislodge existing dust and take it to the dust bag. You'll never be able to prove anything unless you put two never used before brand new vacuums to the test. |
Post# 316616 , Reply# 9   2/24/2015 at 10:05 (3,348 days old) by marcusprit ()   |   | |
It will not be 100% accurate of course but it will give a rough idea. |
Post# 316617 , Reply# 10   2/24/2015 at 11:08 (3,348 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
It was a thought that came to me when I did the pick up tests showing SEBO Felix vs dirty fan Vax VCU02. The videos were created for those who argued that the Felix didn't agitate or whatever...
But I realised in time that even if someone takes a dirty vac and a clean vac and does a pick up test measuring whatever is left in the bag, it isn't exactly accurate judged on the state of the vacuums used. Fair if they are brand new - they won't "add" dirt to the bag other than what has been tested to pick up. |
Post# 316618 , Reply# 11   2/24/2015 at 11:27 (3,348 days old) by marcusprit ()   |   | |
I suppose you could let the cleaner run for a while to suck up any loose dirt inside the machine then clean the brushroll and fit a new bag. |
Post# 316620 , Reply# 13   2/24/2015 at 11:36 (3,348 days old) by marcusprit ()   |   | |
Won't be as accurate as CRI but like you say would be fun to try and I live for having fun :-) |
Post# 316621 , Reply# 14   2/24/2015 at 12:02 (3,348 days old) by kirbymodel2c (Nottingham, England)   |   | |
Post# 316622 , Reply# 15   2/24/2015 at 12:03 (3,348 days old) by marcusprit ()   |   | |
I wonder why the Royal Everlast doesn't get a CRI Gold Award? From what I've seen of it, it's a beast of a cleaner. Possibly too aggressive for some. |
Post# 316623 , Reply# 16   2/24/2015 at 12:04 (3,348 days old) by marcusprit ()   |   | |
Haha I couldn't possibly reveal that on here James! :-p |
Post# 316627 , Reply# 18   2/24/2015 at 12:43 (3,348 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
I wouldn't find it fun to see what vacuum rips my wool carpets to shreds; based on the £3000 paid to buy and install the carpets in the first place.
Whilst it is "fun" to see how much a vacuum picks up in a versus test, you also forget that it also depends on the condition/texture of the bristles on the brush bar. Aggressive will remove more than necessary in my experience compared to softer bristles. |
Post# 316629 , Reply# 19   2/24/2015 at 12:45 (3,348 days old) by Blackheart (North Dakota)   |   | |
I'm going to guess filtration brings it down, same thing for sanitaire.
While not exactly scientific i've managed to get my hands on some hot pink sand. I do have a fairly plushy rug in the basement where my collection sits. to see how they compare to each other i've been pouring some sand then spreading and grinding it in with my shoes. The best performers were the direct and tandem air machines both the kirby g6 and the riccar radiance had all visible debris up in 2 passes (2 forward and 2 back) The lindhaus Healthcare pro took 3 the Simplicity 7 needs a new belt as i heard some squealing but it took 4 this will be re-done when i get a new belt. The miele S7 freshair takes about 4 but there's almost always a little patch left after 4 passes, i have tried both the deep pile and low pile settings. Oreck XL-21 3 passes Oreck XL Ultra 9-10 passes |
Post# 316632 , Reply# 22   2/24/2015 at 12:58 (3,348 days old) by Blackheart (North Dakota)   |   | |
Post# 316633 , Reply# 23   2/24/2015 at 13:04 (3,348 days old) by marcusprit ()   |   | |
I think CRI should adopt a similar method as the EU test. Ratings from A to G for Carpet performance, Filtration, Energy and Noise that would give a clearer picture |
Post# 316635 , Reply# 24   2/24/2015 at 13:16 (3,348 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 316637 , Reply# 25   2/24/2015 at 13:19 (3,348 days old) by marcusprit ()   |   | |
I wasn't saying there was. Would just be interesting to see how much the difference is between a direct air such as a Kirby and the best clean air machines. |
Post# 316638 , Reply# 26   2/24/2015 at 13:19 (3,348 days old) by turbomaster1984 (Ripley, Derbyshire)   |   | |
Post# 316639 , Reply# 27   2/24/2015 at 13:23 (3,348 days old) by marcusprit ()   |   | |
To be honest Stan is probably correct with his statement. |
Post# 316640 , Reply# 28   2/24/2015 at 13:25 (3,348 days old) by turbomaster1984 (Ripley, Derbyshire)   |   | |
Post# 316641 , Reply# 29   2/24/2015 at 13:25 (3,348 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 316647 , Reply# 33   2/24/2015 at 13:33 (3,348 days old) by turbomaster1984 (Ripley, Derbyshire)   |   | |
Post# 316648 , Reply# 34   2/24/2015 at 13:35 (3,348 days old) by Kirbysthebest (Midwest)   |   | |
Turbo, Again I said I didn't want to get in a show me yours contest, but since you made the challenge to Stan, I am going to assume that you have evidence to the contrary so please present it to the class to examine. |
Post# 316649 , Reply# 35   2/24/2015 at 13:36 (3,348 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 316650 , Reply# 36   2/24/2015 at 13:37 (3,348 days old) by marcusprit ()   |   | |
I've used a Riccar Brilliance and you're correct it is a fantastic machine in my opinion they match a Kirby and are more user friendly. |
Post# 316652 , Reply# 37   2/24/2015 at 13:38 (3,348 days old) by marcusprit ()   |   | |
Thanks Stan I'll let you know :-) |
Post# 316653 , Reply# 38   2/24/2015 at 13:42 (3,348 days old) by turbomaster1984 (Ripley, Derbyshire)   |   | |
Post# 316657 , Reply# 40   2/24/2015 at 13:58 (3,348 days old) by turbomaster1984 (Ripley, Derbyshire)   |   | |
typo - used not sued.
You need to lighten up and realise Kirby isn't necessary the best given that theres been millions of different models produced all over the world over the past hundred years so theres no way you have used every one. This is a forum and anyone can challenge broad statements like those made here today especially when they may not actually be true. Your 60 years experience should of taught you that. |
Post# 316659 , Reply# 41   2/24/2015 at 14:07 (3,348 days old) by marcusprit ()   |   | |
If there is a cleaner that will clean deeper than a Kirby, Royal or Riccar Radiance I'd love to try it out. :-) |
Post# 316664 , Reply# 43   2/24/2015 at 14:31 (3,348 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 316665 , Reply# 44   2/24/2015 at 14:35 (3,348 days old) by marcusprit ()   |   | |
I recognise that carpet haha |
Post# 316676 , Reply# 45   2/24/2015 at 16:06 (3,348 days old) by parwaz786 ( )   |   | |
Here's a torture test with my Dyson DC14. I think it did pretty good for a clean air vacuum, but air am not saying its the best. CLICK HERE TO GO TO parwaz786's LINK |
Post# 316699 , Reply# 48   2/24/2015 at 19:24 (3,348 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Oh dear god.
So, does everyone have the same kind of carpet worldwide? Or are we just being fooled into believing that Kirby is indeed the best on ALL carpeted types? End of the day, I agree with Rob (Turbomaster) AND of the points that I have raised. To me, the tests of vacuum versus vacuum is never going to prove anything more than which one has a better brush roll or which one might have a better bag capacity. No one has yet mentioned anything about different carpet textures - surely to god that has to be taken into consideration as well? After all, with brand new carpet, there would be far much more light fibre taken off compared to an older piece of test carpet, where a fairer pick up would show far more transparent results, particularly if "deep down grit" was laid down for vacuums to pick up. And when does it become apparent as to how many sweeps are required to pick up sand before the damage in the carpet actually sets in? |
Post# 316737 , Reply# 54   2/25/2015 at 11:48 (3,347 days old) by marcusprit ()   |   | |
That it a good method Harley I might try that :-) |
Post# 316835 , Reply# 55   2/26/2015 at 07:20 (3,346 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Its a handy list but you forget to add "Use a test machine that has never been used before."
My original thought still applies - you can test any 2 old/used vacuums together with fresh bags or 2 any old bagless uprights and fresh filters; but it is what inside it FIRST that can easily make the testing void when it comes to pick up. Both vacuums have to be new, both vacuums have to be unused. I wonder how many videos online indicate true testing like this? More worringly, those who worry about it are going on a "sold as seen" campaign. |
Post# 316850 , Reply# 57   2/26/2015 at 11:34 (3,346 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
If you test something that has clean bags, clean filter, clean bin, clean brush roll, everything clean - then surely you'll get fairer test findings.
Im not entirely sure why you are presenting the idea of the SEBO's geared belt driven brush roll compared to a vacuum with a stretchable belt though. Its performance can degrade, as can the brush roll fitted with a stretchable belt - i.e threads that get wrapped around the brush roll and anything that gets clogged on the brush roll surely weakens both belts - not to mention also crushing the bristles which can further impede pick up. The geared belt may not snap the first time around, but in time it will if its brush roll continually gets clogged or weakens the hold. |
Post# 316988 , Reply# 60   2/27/2015 at 21:41 (3,345 days old) by sptyks (Skowhegan, Maine)   |   | |
4
Sprockkets: I guess you never heard that it is a fact that the greater the distance the fan is from the carpet, the more airflow and suction you loose.
Look at the Direct Air Royal, Kirby and the older Hoover Convertibles. Their performance is excellent and they only need a 350 to 500 watt motor to do it. Why? Because the motor and fan is only 3 to 4 inches from the carpet where airflow is at maximum.
Now take a look at your typical Bypass air machine. The motor and fan is 3 to 4 feet of internal piping and external hose from the carpet, therefore airflow is greatly reduced. And we all know that it is Airflow, Agitation and Suction (in that order) that cleans carpet the best.This is why most Bypass sair vacuums need a 1000 - 1440 watt motor, and the performance is still less than a Direct Air machine will provide.
Check out the link below for a better explanation:
CLICK HERE TO GO TO sptyks's LINK |
Post# 317129 , Reply# 62   3/1/2015 at 13:36 (3,343 days old) by marcusprit ()   |   | |
How poorly Dyson agitates? You need to watch this video I think it will change your mind. :-) CLICK HERE TO GO TO marcusprit's LINK |
Post# 317134 , Reply# 64   3/1/2015 at 14:11 (3,343 days old) by marcusprit ()   |   | |
Well I have that Dyson and I can tell you it does a fantastic job I'm very impressed with it. And I've owned some very good uprights including Miele S7 , Sebo Felix and Kirby Diamond. :-) |
Post# 317207 , Reply# 66   3/2/2015 at 08:56 (3,342 days old) by marcusprit ()   |   | |
Haha hope you enjoyed them Joe :-) So what cleaner do you use at work? |
Post# 317219 , Reply# 69   3/2/2015 at 11:12 (3,342 days old) by sptyks (Skowhegan, Maine)   |   | |
Sprockkets: You are dead wrong when it comes to your opinion that Direct Air vacuums and Bypass Air vacuums have the same amount of airflow no matter how far the fan is from the carpet. A Direct Air Vacuum has at least 5 times more airflow than a Bypass Air machine and I have proven it with my own Baird Airflow meter:
If I remove the floor nozzle from my Kirby Sentria and connect the Baird meter directly to the fancase opening where the meter is only 1 inch from the fan, the airflow pegs the meter at a "10". Now if I remove the Baird meter and attach the 6 foot hose instead and then attach the Baird Meter to the end of the hose, I get a reading of m"7" on the meter.
Now if I disconnect the hose from the floor head of my Hoover WindTunnel Air, and attach the Baird meter to the end of that hose I get a reading of "2" on the Baird meter. Now how do you explain that?
Click the link to read an article published by "Goodvacs" performing airflow testing on a Kirby and a Dyson using the Baird meter: CLICK HERE TO GO TO sptyks's LINK on eBay |
Post# 317221 , Reply# 70   3/2/2015 at 11:16 (3,342 days old) by marcusprit ()   |   | |
I know what I'd like to do with your Baird Meter! Haha |
Post# 317224 , Reply# 71   3/2/2015 at 11:37 (3,342 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 317225 , Reply# 72   3/2/2015 at 11:40 (3,342 days old) by kirbysthebest (Midwest)   |   | |
Five minutes on the Naughty Step. We do not smash other people's property. |
Post# 317226 , Reply# 73   3/2/2015 at 11:41 (3,342 days old) by marcusprit ()   |   | |
No I was thinking of sticking it where the sun don't shine :-p |
Post# 317227 , Reply# 74   3/2/2015 at 11:42 (3,342 days old) by kirbysthebest (Midwest)   |   | |
10 Minutes on the Naughty Step. |
Post# 317228 , Reply# 75   3/2/2015 at 11:44 (3,342 days old) by marcusprit ()   |   | |
Hahahaha :-))) |
Post# 317358 , Reply# 77   3/3/2015 at 17:41 (3,341 days old) by sptyks (Skowhegan, Maine)   |   | |
Sprockkets, I'm afraid that you are still wrong. It seems you are confused and believe that suction and airflow are the same thing. They are not. In order to clean carpet really well you need 3 things: (1) Airflow (2) Agitation (3) Suction
In that exact order! If you had a bypass air vacuum that could pull 100 inches of water but can pull only a 3 on the Baird meter, it has poor airflow, and it will not clean nearly as well as a Direct Air vacuum. The Baird meter measures Airflow and that is what's most important.
This video shows the Royal all metal Direct Air vacuum vs three expensive bypass air vacs. Airflow wins all 3 battles here:
Post# 317383 , Reply# 79   3/4/2015 at 00:54 (3,340 days old) by marcusprit ()   |   | |
Suction and airflow are linked together. Without suction theres no airflow. |
Post# 317404 , Reply# 82   3/4/2015 at 07:58 (3,340 days old) by marcusprit ()   |   | |
But it is the fan on the motor that causes a drop in ambient pressure which produces suction which produces airflow. Suction and airflow are linked :-) I'm no physicist either haha |
Post# 317406 , Reply# 84   3/4/2015 at 08:01 (3,340 days old) by kirbysthebest (Midwest)   |   | |
Yes suction and air flow are linked, but as one increases the other decreases. A dead air flow, strong suction. High air flow, low suction. Linked. Optimized. |
Post# 317407 , Reply# 85   3/4/2015 at 08:02 (3,340 days old) by marcusprit ()   |   | |
This post has been removed by the webmaster. |
Post# 317408 , Reply# 86   3/4/2015 at 08:03 (3,340 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Post# 317410 , Reply# 87   3/4/2015 at 08:09 (3,340 days old) by marcusprit ()   |   | |
Positive! Though I might be in a minority on here. Haha :-p |
Post# 317412 , Reply# 88   3/4/2015 at 08:40 (3,340 days old) by Hoover78 (dallas tx)   |   | |
Post# 317413 , Reply# 89   3/4/2015 at 08:55 (3,340 days old) by marcusprit ()   |   | |
Post# 317415 , Reply# 90   3/4/2015 at 09:39 (3,340 days old) by kirbysthebest (Midwest)   |   | |
Thread is drifting. Back to air flow. And BTW, you can have a beach of sand in your carpet. A carpet can hold ond and one half times it's own weight in dirt and still look clean to the naked eye. |
Post# 317422 , Reply# 91   3/4/2015 at 12:13 (3,340 days old) by sptyks (Skowhegan, Maine)   |   | |
Harley is absolutely correct when he explains the concept of Suction vs Airflow!
Here's another way to look at it: A Tornado is a whirl of wind. There is almost no suction involved, but a Tornado can pickup a house and carry it 100 yards with very little or no suction.
Take a look at your average Dyson. There's lots of suction as measured in inches of water, but take out your Baird Meter and measure the Airflow and you'll find there's very little.
Now look at your Kirby or metal Royal and you'll see these numbers are reversed. There's very little suction, but the Baird meter is nearly pegged at "10". Now as the brushroll, spinning at 3900 RPM, brings the dirt to the surface of the carpet, all that Airflow picks up the dirt (just like a tornado) and carries it through the fancase and into the bag. And that's why Airflow is more important than suction.
Post# 317426 , Reply# 93   3/4/2015 at 13:58 (3,340 days old) by sptyks (Skowhegan, Maine)   |   | |
5
Marcus, I want you to understand this concept, so please read slowly what Harley wrote here: "You can also have airflow, like a dryer, where it moves 180 CFM, but it is mass air flow very little suction because the air is being replaced as quickly as it is being removed. The air flow carries out the damp warm air in a dryer, as is the air flow that moves the dirt off the carpet and into the capture system."
Another way to look at it is when you first turn on a Kirby, and the fan starts to spin up, there is a brief moment of suction that starts the air moving through the machine. Once the Airflow reaches full speed, the suction drops off to a small amount because the air inside the floor nozzle is being replaced as quickly as it is removed. Once air is constantly moving at full speed, there is no more need for lots of suction. The reason why the Kirby and Royal have so much airflow is because the opening to the fancase is a full 2 inches in diameter compared to Dyson and similar machines which is between an inch and an inch and a quarter. The Bell Shaped nozzle amplifies the airflow as well. Read the posts above, there is a scientific formula that proves this.
Post# 317427 , Reply# 94   3/4/2015 at 14:01 (3,340 days old) by marcusprit ()   |   | |
That may be true but you still need the suction to get the air flowing :-) |
Post# 317428 , Reply# 95   3/4/2015 at 14:08 (3,340 days old) by marcusprit ()   |   | |
Air Watts = Vacuum suction (inches of water) x Air Flow (cubic feet per minute)/8.5Air Flow (CFM) = √13.35 X D2/Vacuum suction |
Post# 317431 , Reply# 97   3/4/2015 at 14:21 (3,340 days old) by marcusprit ()   |   | |
I agree with you. I read that very slowly :-) |
Post# 317432 , Reply# 98   3/4/2015 at 14:27 (3,340 days old) by kirbysthebest (Midwest)   |   | |
This has been a good discussion, thank you for posing the question. |
Post# 317433 , Reply# 99   3/4/2015 at 14:32 (3,340 days old) by marcusprit ()   |   | |
Well thank you Harley I've enjoyed it too. Very interesting :-) |
Post# 317434 , Reply# 100   3/4/2015 at 14:39 (3,340 days old) by kirbysthebest (Midwest)   |   | |
It's amazing what you can remember from 9th grade Physical Science class. I remember the whole Water well/pump atmospheric pressure chapter. Didn't care for Mr. Schoonover who taught it that much, but that's a different story. |
Post# 317435 , Reply# 101   3/4/2015 at 14:43 (3,340 days old) by marcusprit ()   |   | |
Haha our chemistry teacher had a nervous breakdown cause of us. Oh dear. I was so immature back then. Hard to believe isn't it :-) |
Post# 317436 , Reply# 102   3/4/2015 at 14:50 (3,340 days old) by kirbysthebest (Midwest)   |   | |
You kind of have to have a nut loose to walk into a classroom full of adolescents and turn your back on them. |
Post# 317437 , Reply# 103   3/4/2015 at 14:55 (3,340 days old) by marcusprit ()   |   | |
Especially in a chemistry class with Bunsen burners and the elements to make explosives haha :-) |
Post# 317438 , Reply# 104   3/4/2015 at 15:03 (3,340 days old) by marcusprit ()   |   | |
Only minor explosions though I wasn't Guy Fawkes :-) Americans may need to google that. |
Post# 317496 , Reply# 108   3/5/2015 at 11:26 (3,339 days old) by sptyks (Skowhegan, Maine)   |   | |
Sprockkets: I agree that as airflow decreases, suction increases and vise versa. BUT, I also believe that Airflow and agitation are the two most important ingredients needed for a good deep clean. Bag and nozzle resistance does increase suction a little bit on a Direct Air vacuum, but the amount of airflow through the nozzle along with a well designed brushroll cleans carpet the best.
Marcus: For once I fully agree with your statement on Kirby vs Sebo. Actually, after all I've read on this Forum about the Sebo Felix, it sounds like a fantastic machine and I would love to try one out sometime, but they are horribly expensive here in the U.S. The only thing that would bother me about the Felix is the small but expensive bags.
Post# 317512 , Reply# 110   3/5/2015 at 14:32 (3,339 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
The U.S has commercial versions of the Felix, but they're not as versatile in my experience. They have fixed suction, non-brush roll on/off button and no 3 point neck height adjustment for the handle.
Not only sold under Windsor Axxcess, but also the previous "Flexamatic" label and Dr Schutz with the Dart re-labelled "Carpetwise." Karcher U.S ALSO sells a commercial version of the Sebo Felix. Generally I find a box of Felix bags lasts me a year and a half to 2 years before a new box is required. You get 8 bags in a box which is double the quantity you get with Miele. SEBO don't use litres or quarts as a way of understanding longevity per bag; it really depends on what your home has in terms of the amount of dust. At the very least, a SEBO Felix dust bag in my experience lasts 2.5 months before requiring to be changed, which puts it on a par with Miele's FJM dust bags. Some bags my old Felix has had has gone on for 4 months! |
Post# 317528 , Reply# 112   3/5/2015 at 15:46 (3,339 days old) by dys0nb0y (Luton)   |   | |
Post# 317542 , Reply# 114   3/5/2015 at 17:29 (3,339 days old) by Hoover78 (dallas tx)   |   | |
Bypass or direct air vacuum? |
Post# 317545 , Reply# 115   3/5/2015 at 17:45 (3,339 days old) by dys0nb0y (Luton)   |   | |
Post# 317546 , Reply# 116   3/5/2015 at 18:02 (3,339 days old) by sptyks (Skowhegan, Maine)   |   | |
I guess if a box of Felix bags lasts more than a year that's not so bad. There is a Sebo dealer about 20 miles from me, but he sells the Felix for around $600.00 which is too rich for my blood.
I bought all my Kirby's on ebay for between $50 and $190 except my G3 which I found in the trash. It cost me about $60 for the parts to get it running like new.
I have no desire to own a Dyson, mainly because it's bagless and I don't care for bagless machines. The exception being a Hoover WindTunnel Air that I got cheap. It's great for quick pickups and vacuuming out the shakeout bag of my vintage D50. I empty the Hoover in the trash bin in the laundry room of my apartment building so the dust cloud doesn't come near my very clean apartment.
Post# 317548 , Reply# 117   3/5/2015 at 18:09 (3,339 days old) by dys0nb0y (Luton)   |   | |
Post# 317552 , Reply# 118   3/5/2015 at 18:24 (3,339 days old) by Kirbysthebest (Midwest)   |   | |
It was a discussion. Draw your own conclusions.
Poor dead horsey--Whack, Whack!!
This post was last edited 03/05/2015 at 21:15 |
Post# 317616 , Reply# 121   3/6/2015 at 15:18 (3,338 days old) by sprockkets (Eau Claire WI)   |   | |
Also if you don't want a kirby but want direct air, what about the Koblenz? I used a Sanitaire in the past, and didn't really like it. |
Post# 317619 , Reply# 122   3/6/2015 at 15:42 (3,338 days old) by ralph123 (Little Rock, AR)   |   | |
If you want direct air, but don't want a Kirby then get a Riccar/Simplicity/Maytag 9-lb upright. |
Post# 317645 , Reply# 124   3/6/2015 at 18:36 (3,338 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 348041 , Reply# 131   3/20/2016 at 04:50 (2,958 days old) by Shrink1982 (Indianapolis)   |   | |
I have owned many vacuums. Bought the purple Dyson in 2005 (I don't remember the name). It lasted five years and now it makes a loud noise as if something is caught in it. Hated that thing. Am also not a fan of bagless. You have to breathe in that stuff every time you clean it out. Not fun. I then bought a refurbished Kirby Diamond Edition around 2011, I believe. I always loved Kirbys as my grandparents has one. Had a salesperson come to my house once. Biggest mistake. Their sales tactics are ridiculous. So, the Kirby Diamond cleaned very well but anything with the hose was a no go. I never used it because it was such a pain to use and didn't have very good suction. I also noticed the Kirby would lose suction after starting to fill, and I was using the cloth bags. Even though the full line is only halfway up the bag, it would start to lose suction long before it got there. What was the point in a large bag if I could only fill it less than halfway before losing suction? The suction and airflow were quite powerful. It would definitely stick to the lino in the kitchen but, with such a large head, was impractical for cleaning under low furniture. Also, it was horrible on rugs, even with the motor on low.
Last October I went for it and purchased a SEBO d4 Premium. I really like it. The first thing I noticed was how it groomed the pile. For some reason, the Kirby never did that as well. I don't know if it was because it as so heavy it matted it down but the SEBO power head is very good at grooming. Sure, it doesn't have as much airflow at the head but I don't really need that much. We vacuum often and don't wear shoes in the house. Since our cat passed away two years ago, there just isn't nearly as much dirt to pick up. Mostly just dust which the SEBO does really well with. I love the tools, the build quality and the ease of going from hard surfaces, to carpet, to above floor cleaning. For us, it is the best compromise. I don't kid myself into thinking it does as well on carpets as the Kirby, however, if my carpets were to get really bad I would use the Kirby every month or so. Also, if one vacuums frequently, they may not need a direct air vacuum. If you put it off for a month or so, much of the dirt and dust will get matted to the bottom of the carpet and I would think something like a Kirby would be the vacuum of choice. We vacuum so frequently dirt and dust don't have time to get to the mat. And, as I said, there isn't much dirt coming in. My point is different vacuums work better for different people and different environments. You also have to take the type of carpet into consideration. Something like a berber or short pile isn't going to need as much airflow as a short or long shag. As we continue to replace our carpets with hardwood and rugs, something like the Kirby becomes less of a need. I probably will vacuum my carpets with the Kirby, for good measure, as I haven't had it out since getting the SEBO. I do miss it and it is nice to switch things up. |
Post# 348043 , Reply# 132   3/20/2016 at 05:25 (2,958 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Well said, Shrink1982 - the whole point in your statement that I read was "you also have to take the type of carpet into consideration," which is one of the more important criteria involved when choosing a vacuum. The brands don't tend to fully validate that, not because there are so many types of different carpet, but rather because it involves more than just pasting an approval seal from one of many recognisable brands of carpet to justify that model's existence.
Post# 348184 , Reply# 133   3/21/2016 at 16:29 (2,957 days old) by suckolux (Yuba City, CA)   |   | |
Post# 348196 , Reply# 134   3/21/2016 at 19:15 (2,957 days old) by Miskini (Northville, Michigan )   |   | |
Post# 348239 , Reply# 135   3/22/2016 at 10:09 (2,956 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 348248 , Reply# 136   3/22/2016 at 12:55 (2,956 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Post# 348414 , Reply# 137   3/23/2016 at 21:44 (2,955 days old) by Marks_here (_._)   |   | |
Post# 348434 , Reply# 138   3/24/2016 at 05:28 (2,954 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
The VK130 has had some terrible reviews in Germany where the suction is slated and I found that info online after I had bought mine. I can see why.
I was using mine a few days ago without the PN added - and I found the fault why suction is greatly decreased; it is the carbon motor filter sponge. It protects the motor but there's already a HEPA filter on board and the filter bags that could work just as well without it. Removing the carbon filter and replacing it with a home made cut to fit Miele AirClean filter suddenly gives my VK130 far more suction power. No wonder Vorwerk improved the design on the later models with a similar microfilter grid at the top of the motor.
