Thread Number: 25608
electrolux 60 lx how to adjust bag release |
Post# 287533 , Reply# 1   7/6/2014 at 21:47 (3,581 days old) by electrolux137 (Los Angeles)   |   | |
. Look inside the compartment on top of the motor unit where the cord plugs in. (Lift up the lid.) If you're lucky, there will be a little metal tool clipped inside there that looks something like a rectangular soda can pull-tab. It was called "The Basement and Attic Key," used to keep the machine from ejecting too soon when fine, powdery dirt was being vacuumed up. Lacking the tool, you can use a golf tee -- wedge it (pointed end first) inside the opening over the little metal tab sticking out from the lower-left side of the front cover and it will keep the ejection process from happening. (Note that if your machine still has the metal ejection apparatus inside the bag cage, you'll have to push it back down to the back of the bag cage before wedging the golf tee against the metal lever.) |
Post# 287637 , Reply# 3   7/7/2014 at 13:45 (3,580 days old) by electrolux137 (Los Angeles)   |   | |
Post# 287638 , Reply# 4   7/7/2014 at 13:45 (3,580 days old) by cat1560 ()   |   | |
edit i sorta want the automatic bag ejection to work its kind of the whole point i love this vacuum and if you wedge the key to stop it from automatically ejecting it makes it no different then other vacuums |
Post# 287647 , Reply# 5   7/7/2014 at 14:12 (3,580 days old) by cat1560 ()   |   | |
is there anyway you can adjust it by using simaler tools to what the sales men used to adjust them in your house since mine dose not have a dial |
Post# 287677 , Reply# 10   7/7/2014 at 17:31 (3,580 days old) by cat1560 ()   |   | |
what wire also is it possible for them to come un calibrated because when mine is a quarter way full of normal everyday not fine dust it still ejects |
