Thread Number: 25358
Hoover Convertible Thrift Find |
Post# 285016   6/17/2014 at 09:37 (3,601 days old) by beekeyknee (Columbia, MO)   |   | |
Thought I'd sneek over from the washer side and show you guys what I found yesterday. I must be reverting back to my youth as I was wild about vacuums then, so yesterday I went hunting for some unknown reason and found this.
It's nothing extreamly special but it was in really good shape so I snaged it for $15.00. I gave it a complete tear down and rebuild. There wasn't much wrong with it except it needed a new snap on the bag and new paper bag and belt. I don't have the Hoover grease gun, but I managed to work quite a bit of grease in the bearings after washing them out with kerosene. Unfortunately it doesn't have the original plug. Either I'm getting weaker in my old age or I don't remember correctly, but this thing really has a lot of suction. I guess I'm just spoiled by my power drive Kirby. It's fun to play with a Convertible again. |
Post# 285023 , Reply# 1   6/17/2014 at 09:49 (3,601 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 285045 , Reply# 2   6/17/2014 at 11:36 (3,600 days old) by marks_here (_._)   |   | |
Post# 285065 , Reply# 3   6/17/2014 at 13:13 (3,600 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Excellent machine, (even for a 'basic' model).LOVE that color..how could you not????? My next door neighbor had this cleaner as her 'second floor' (extra cleaner). I used to hear her run it all the time when I was a kid. When she died, it was given to me. NOT a trash find, mind you. But... a nice piece of my childhood.
Post# 285193 , Reply# 4   6/18/2014 at 02:51 (3,600 days old) by beekeyknee (Columbia, MO)   |   | |
Pardon my ignorance, but since the plug has been replaced on this machine, what is the proper length of the cord for this model? It's 15 ft. , 9 inches long. Seems kind of short.
When I tore down the machine for it's rebuild, I wasn't quite able to get the motor as quiet as it was originally. I put the brushes back in it the way they came out. They were in good shape. I fiddled with the top motor bearing for quite awhile and got it pretty good but not as quiet as it should be. Makes a bit of a grinding sound when it's winding down. Alex, Thanks on the KitchenAid. It's original post is in AW's Imperial section last week. |
Post# 285204 , Reply# 5   6/18/2014 at 09:40 (3,600 days old) by rugsucker (Elizabethton TN)   |   | |
Very nice Mo 36! Others will know more but some differences are-- Standard(31,32,33,---)-shorter cord,half bumper,snaps on bag. Deluxe(65,66,67---)-longer cord,full bumper,zipper on bag. Both-QUALITY with same motor,fan,agitator,belt,bag,etc. |
Post# 285224 , Reply# 6   6/18/2014 at 12:42 (3,599 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Keep in mind that houses in the 1950s and 1960s were smaller then houses of today, you didn't need 30,40,50 feet of cord, you could walk outside and start vacuuming the car without ever changing and outlet with such cords! I doubt much of the cord has been lost, I would measure my U4047 cord for you, but I put it into 'cold storage' the other day! I'm sure our resident HOOVER guru, John Long (gottahaveaHOOVER) can fill me in here!
If the Convertible is louder than it's usual famous hum, the first culprit to check is the fan. You and me both LOVE how easy Convertibles are to work on! Take the hood off and remove the 5 screws on the very bottom. The motor will lift right off, check the fan for any broken blades or other damage. Slowly turn the fan, listen closely to find if the grinding is coming from something stuck between the fan and the motor. If it is not, then your bearings are the likely culprit (another EASY HOOVER fix!) |
Post# 285249 , Reply# 7   6/18/2014 at 15:41 (3,599 days old) by beekeyknee (Columbia, MO)   |   | |
I've already done all of that, so it might be the lower bearing. It's odd though. After I cleaned and lubed the bearing it startede turning smoother. And it's not loose either. No slop at all.
It seemed like it had something to do with how the top bearing plate went back on. When I adjusted it and retightened the screws the sound got better. The first time I put it on it wasn't lined up properly and was binding the rotor. It's like working on an old fan. If you don't get everything lined up properly, it won't run. I took it off and adjusted until it didn't bind any more but it still wasn't as quite as when I took it apart. Sounds like brush noise, but I don't know why. I put them back the way they came out. They seated good visually. I cleaned the top bushing with a Q-Tip and some Zoom-Spout oil, then put a few drops of Zoom Spout in the top bushing, turned it right side up on a paper towel and let it set for awhile. I think I remember reading that this was the best way to treat that bushing. It's really not too bad. Maybe I should leave well enough alone unless someone has a better suggestion. |
Post# 285273 , Reply# 8   6/18/2014 at 17:52 (3,599 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 285277 , Reply# 9   6/18/2014 at 18:10 (3,599 days old) by constellation86 (Roy, UT)   |   | |
Nice find! The cord would have been 16 feet long originally. The deluxe models were 20 feet. I tend to use an extention cord with short ones like this. Nicholas |
Post# 285283 , Reply# 10   6/18/2014 at 18:36 (3,599 days old) by Gus ( Montevideo Uruguay, South Am.)   |   | |
Hey Guys, you are a fountain of information. I always learn sth. new from you all! Thank you for sharing your knowledge. Gus |
Post# 285290 , Reply# 11   6/18/2014 at 19:08 (3,599 days old) by beekeyknee (Columbia, MO)   |   | |
It makes the same sound with the belt off. I turned the fan by hand and can hear quiet clicking sounds a regular intravals. It has to be brush noise. The comutator was clean and shiny. I may take the hood off and take the brushes out and see if the clicking stops. Then I'll know. It could be possible that I got one in upside down and it hasn't seated.
Post# 285327 , Reply# 13   6/19/2014 at 00:08 (3,599 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
That's your problem! The carbon brushes are riding on the armature! Go ahead with taking the brushes out, that will eliminate the possibility of another issue causing the issue! If you find the carbons are the cause, clean the armature with a cleaning stone. Take the hood off and run the motor. You're likely to see sparks fly everywhere.this means your carbon brushes are not properly seated, you've likely installed them incorrectly, perhaps you have them upside-down or reversed?
Post# 285345 , Reply# 14   6/19/2014 at 02:21 (3,599 days old) by kirbyvertibles (Independence, KS)   |   | |
That is something special lol. That was the very last to be called the Convertible special, meaning the budget model. The fact this still has it's original bag is special. Tom Anderson had once told me these 36 bags were rare as hens teeth and I have to agree. I have come across many of this model as well as the gold 704 models with replacment bags.
