Thread Number: 22990
Hoover Turbopower Motor Wiring Issue
Post# 257354   11/23/2013 at 05:15 (3,812 days old) by beko1987 (Stokenchurch, United Kingdom)
Hi Guys.
When stripping my Turbopower Plus apart, one of the wires leading to the carbon brush holders snapped.
No worries, I though, I have a spare coil in the garage.
However, it came from a motor with a headlight, so has an extra spade connector.
The black wire goes to a carbon brush. The brown cut off wire I think went to the bulb holder. Does it matter where I plug it in? Both lead to the coil somewhere.
From DC08 101-UK-A-20983
Thanks!
Post# 257450 , Reply# 1   11/24/2013 at 04:29 (3,811 days old) by DaveTranter (Central England, U.K.)
Motor wiring
It's hard to tell just by looking, but the manufacturers may have used the motor windings as a voltage transformer for the headlight bulb. Was the lamp 110V?? If that is the case, then you will need to be sure that you connect to the correct terminals. Since I have no practical experience of this machine, I don't know. I am sure that there are others who will know for sure, but I wouldn't want you to destroy a good set of field windings, and possibly your armature, too, by a wrong connection.
All best
Dave T
Post# 257456 , Reply# 2   11/24/2013 at 07:27 (3,811 days old) by beko1987 (Stokenchurch, United Kingdom)
Hi Dave. No idea what the lamp voltage is tbh. But after your advice I'm going to buy my step dad a bottle of ale and ask him to solder the old one together, if I can find the old one that is...
