Thread Number: 22963
What model is this 20's Eureka?
Post# 257030   11/20/2013 at 14:12 (3,810 days old) by KirbysNphones ()
I brought this old beast hiome the other day, and it was in a bad way. You would plug it in, turn it on, and it would make a horrid grinding/squealing noise and shoot sparks out the back of the motor!
Well, After I got it home, looked it over, and started work on it, I was determined to bring it back to life. First I took the motor apart and found most of the problem, it had been greased WAY too much, and the old grease was on the carbon motor brushes, the commutator and the rotor windings. After cleaning out the motor, lubing it sparingly with 30 Wt non detergent, and re wiring it it runs smoothly and doesn't shoot sparks!
Now what model is it? 9 or 10, or something else?
I need to make a new front wheel for it, probably going to get a dowel rod the same size as the other wheel and use that. Also have some more polishing to do as well. Too bad it doesn't have the hose or tools, but it does have a worn out brush that went on the floor nozzle.
CLICK HERE TO GO TO KirbysNphones's LINK
Post# 257060 , Reply# 1   11/20/2013 at 19:42 (3,810 days old) by KirbysNphones ()
looks like a model H
www.vacuumland.org/cgi-bin/TD/TD-...
Post# 257063 , Reply# 2   11/20/2013 at 19:53 (3,810 days old) by portable (Corvallis, OR)
portable's profile picture
Nope, that posting of mine "way back when" is an error. I believe it is a Model 10.
Post# 257078 , Reply# 3   11/20/2013 at 20:35 (3,810 days old) by cb123 (Mobile, Al.)
cb123's profile picture
It's a early 1921 model 9.
Post# 257093 , Reply# 4   11/20/2013 at 22:31 (3,809 days old) by KirbysNphones ()
ok, so it's either a 10 or 9, I'm leaning towards a 9, because the 10 has the wheels on the machine itself, whereas the 9 (like mine) has the wheels on the nozzle.
And at around 90+ years old, it's one of my oldest vacs, right there with the Hoover Duster! I'd like to see a vac from a big box store last 90+ years!
Post# 257111 , Reply# 5   11/21/2013 at 01:06 (3,809 days old) by cb123 (Mobile, Al.)
To the left is a 1927 Eureka model 10, and to the right is a 1923 version of the 1921 model 9. I have a spare wheel assembly if you need it.
Post# 257113 , Reply# 6   11/21/2013 at 02:29 (3,809 days old) by cb123 (Mobile, Al.)
This is the "Holy Grail" of Eureka repairman books. It covers 1936 all the way back to the model A ( AKA Model 1 ). No doubt about it, yours is a early model 9.
Post# 257127 , Reply# 7   11/21/2013 at 07:11 (3,809 days old) by dysonman1 (the county)
It's a model 9. There can be no other choice, as it has the wheels on the nozzle.
Post# 257298 , Reply# 8   11/22/2013 at 15:18 (3,808 days old) by KirbysNphones ()
Wheel assembly
cb123, I might take you up on that, I'll send you a PM. Thanks for the info guys!
Post# 257299 , Reply# 9   11/22/2013 at 15:22 (3,808 days old) by KirbysNphones ()
Ok, see no way to send a PM, so I'd be interested nonetheless.
You wouldn't happen to also have the "spring" that holds the handle up too, would you? It's a metal strip with a loop in the end that is on the back of the fan housing, and it locks the handle in the upright position.
Post# 257437 , Reply# 10   11/23/2013 at 23:46 (3,806 days old) by cb123 (Mobile, Al.)
KirbysNphones,
On the top right of the page is the MSG block - Press on it to get into your messages. Then, you will see a thin rectangle at the top right, highlighted light blue - click on it. Then find cb123 on the member list - click that in and you will be able to send me a message with your address. Calem
Post# 257476 , Reply# 11   11/24/2013 at 15:04 (3,806 days old) by KirbysNphones ()
Says it's for "upgraded users only". seriously they block too much stuff for the "regular" users. Most other forums have the messaging system available to ALL users.
Email me at wtekmann@juno.com that email is so full of spam, I really don't care who knows it. Let me know on here, so I know to check it.
Post# 257501 , Reply# 12   11/24/2013 at 20:10 (3,806 days old) by cb123 (Mobile, Al.)
This post has been removed by the member who posted it.
Post# 257518 , Reply# 13   11/25/2013 at 00:02 (3,805 days old) by cb123 (Mobile, Al.)
Will,
This is the "Edison Victrola" - I think it's from between 1910 to 1915 (Not Sure)But it has the Edison model 1 motor, and the cabinet has some marked differences then the later "Victors". This thing is almost as loud as a modern stereo record player, and the fidelity is pretty high too. The vanes in front is how you can control the volume. Thirty cranks and it's good for one side of a disc. Think about becoming an upgraded member - you want have to suffer thru the agonizing commercials anymore!
Post# 257519 , Reply# 14   11/25/2013 at 00:09 (3,805 days old) by cb123 (Mobile, Al.)
Will, just one more thing...
I almost forgot, post here when you get your parts in - so that I know if you got'em or not. Thanks, Calem
Post# 257572 , Reply# 15   11/25/2013 at 19:30 (3,805 days old) by cb123 (Mobile, Al.)
Will,
Your parts are on the way.
Post# 257719 , Reply# 16   11/27/2013 at 11:02 (3,803 days old) by KirbysNphones ()
Thanks! That is one cool record player too. I am seriously thinking of upgrading, but not because of the adverts, as I don't see any! (I use Adblock Plus in Firefox) :)
Happy thanksgiving!
Will
Post# 257734 , Reply# 17   11/27/2013 at 17:19 (3,803 days old) by KirbysNphones ()
Got the parts today, thanks again Calem!
Post# 257762 , Reply# 18   11/27/2013 at 21:53 (3,803 days old) by cb123 (Mobile, Al.)
That was fast, glad you got it! Have a Happy Thanksgiving too! Calem
Post# 311467 , Reply# 19   1/9/2015 at 23:32 (3,394 days old) by cheapswede ()
Need Part
Would anyone happen to have the front latch that holds the nozzle on the model 10? Mine has the original screw and spring, but the nozzle is currently being held on with a fender washer.
email is cheapswede@hotmail.com
Thanks!
Post# 355705 , Reply# 20   7/8/2016 at 22:39 (2,849 days old) by KirbyCollector (Columbus Ohio USA)
kirbycollector's profile picture
These are machines I want
I'm getting a Eureka Standard from a friend sometime. The standard is about identical to a model 9.
Post# 356066 , Reply# 21   7/14/2016 at 19:54 (2,843 days old) by cb123 (Mobile, Al.)
Once you'll get it, you'll certainly love it! Those are some truly magnificent machines...No doubt about it!
