Thread Number: 22626
Desperately need a replacement roller on my Riccar Model 8900!!! |
Post# 252857 , Reply# 1   10/13/2013 at 20:18 (3,847 days old) by dustin (Jackson, MI)   |   | |
Post# 252876 , Reply# 4   10/13/2013 at 22:35 (3,847 days old) by dustin (Jackson, MI)   |   | |
Duh... I guess I should have read it more thouroughly. Does your vacuum have the option to shut the brushroll off for hard floors? If it does, it seems like I have heard something about that mechanism going on the fritz and not working at all. It seems like it was something to do with the tabs on the end and their position. It looks to me like you could use a new set of brush strips as well.
Post# 252923 , Reply# 5   10/14/2013 at 10:18 (3,846 days old) by dysonman1 (the county)   |   | |
It's not broken at all. The pic you posted has the brush bar in the bare floor position so that the belt will rotate but the brush roller will not. When you reinstall the brush roller, those little 'snakes teeth' go DOWN, and the hole for the linkage rod goes UP. Once in place, put the rug/floor selector in the Carpet position (it's the lever on top of the nozzle housing) and your problems will be solved. See the proper position of the linkage rod in the picture.
Post# 252941 , Reply# 6   10/14/2013 at 13:12 (3,846 days old) by dysonman1 (the county)   |   | |
