Thread Number: 22551
Hoover centralized vacuum- stopped working partially |
Post# 252220 , Reply# 1   10/6/2013 at 20:07 (3,854 days old) by piano_god (British Columbia, Canada)   |   | |
Are you positive that the vacuum in your garage (not just the powerhead) is turning on when you move the switch to carpet? If so, it is likely an issue with the switch in the hose. If the hose is made by Plastiflex, you'll replace the whole wiring harness. This post was last edited 10/06/2013 at 20:26 |
Post# 252244 , Reply# 2   10/7/2013 at 08:49 (3,854 days old) by HooverCelebrity (Germany)   |   | |
It sounds like a problem with the swicth at the end of the hose to me as well. If it's a Hoover made hose, this is the part that would need to be replaced. Switch - part #: 28267001 |
Post# 252481 , Reply# 5   10/10/2013 at 00:19 (3,851 days old) by piano_god (British Columbia, Canada)   |   | |
Post# 252625 , Reply# 6   10/11/2013 at 19:26 (3,849 days old) by r_u_live ()   |   | |
its model # S5610 i tried to do reset and on/off switch on the top part of unit(pic attached) but no luck, looks like motor is bad? |
Post# 252630 , Reply# 7   10/11/2013 at 20:08 (3,849 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 252631 , Reply# 8   10/11/2013 at 21:07 (3,849 days old) by piano_god (British Columbia, Canada)   |   | |
@super-sweeper: The owner mentioned they tried the manual switch and it did not work. This switch is not in the on position in normal use.
The issue is likely either with the motor or the relay, r_u_live.
Try taking out those two spade connectors and short-circuit them with a pair of needle-nose pliers. If it makes a click sound, the motor is likely bad. Your machine uses an Ametek Lamb 116472.
Post# 252671 , Reply# 9   10/12/2013 at 10:45 (3,848 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 252685 , Reply# 11   10/12/2013 at 11:52 (3,848 days old) by piano_god (British Columbia, Canada)   |   | |
