Thread Number: 22483
Vax 121 tripping the electrics |
Post# 251709 , Reply# 1   9/30/2013 at 13:13 (3,861 days old) by parwaz786 ( )   |   | |
I hear a lot of stories about VAX's tripping the breaker |
Post# 251712 , Reply# 2   9/30/2013 at 13:53 (3,861 days old) by James (Ware, Hertfordshire, UK)   |   | |
Post# 251798 , Reply# 5   10/1/2013 at 16:45 (3,859 days old) by James (Ware, Hertfordshire, UK)   |   | |
Hmmm, I suppose it could be the suppressor. When one of my Vax's did this I changed the motor and fitted my suppressor to the new motor and that worked fine.
So was my motor that had gone. Had a 1200W motor I think it was in briefly until I found another 900W one, was a right beast. Really got the cleaning solution through that washing head when vaxing lol. To get those handle bolts off, I sometimes use a pair of long nose pliers, it can chew the bolt up a little but it does work if you grip hard enough. I never tried but maybe a swan neck/ offset spanner may work. Once I used a socket on the end of a flexi drive coupler that I have in my screw driver set which kind of works although was awkward. |
Post# 252196 , Reply# 6   10/6/2013 at 14:28 (3,855 days old) by irish-vac-king ()   |   | |
ME TO |
Post# 252238 , Reply# 7   10/7/2013 at 03:59 (3,854 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Cheers for the diagnostic info! Still need to have a go at it! I'm just using my good new vax motor on the old kit! |
Post# 254589 , Reply# 11   10/30/2013 at 07:49 (3,831 days old) by dansvaccentre12 ()   |   | |
hi sam I hav a lux z350e that's dunn the same thing yet don't no our rewire it back up its got 4 wires come of the speed control. and one off the on off button other off cable rewind |
Post# 254598 , Reply# 12   10/30/2013 at 11:19 (3,831 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Do they all go into the suppressor and come out again? Have to say I don't know about the lux. If you could pop some pictures up that would help, it took me a while to figure it out. Failing that, put a new thread up, with lots of pics and the Electrolux beards will help! |
Post# 254617 , Reply# 13   10/30/2013 at 15:12 (3,831 days old) by dansvaccentre12 ()   |   | |
OK WILL DO SORT IT AT WEEK END THKS SAM |
Post# 254699 , Reply# 14   10/31/2013 at 03:31 (3,830 days old) by dysondestijl (east midlands, UK)   |   | |
Hey I have a lux 350E I love it its very quiet and pleasant to use :) |
Post# 254712 , Reply# 15   10/31/2013 at 05:57 (3,830 days old) by dansvaccentre12 ()   |   | |
I did an till it started smokein from the suppressor best cleaner out |
Post# 379103 , Reply# 16   10/1/2017 at 16:40 (2,398 days old) by biggy (Brean,Nr Burnham-on-sea)   |   | |
after you get them out use a hacksaw to cut slots across the bolt head you can then use a slotted screwdriver instead of socket or pliers to put them back in place. |
