Thread Number: 21407
Miele DOA |
Post# 239559 , Reply# 1   7/10/2013 at 00:42 (3,942 days old) by piano_god (British Columbia, Canada)   |   | |
this sounds like an issue with the cord rewind. Specifically, the spool has likely come away from the contacts located on the stationary part of the assembly.
Check the continuity with a wire tester first to confirm. Start by going from the plug to spade connectors in the spool, then followed by spade connectors in the spool to spade connectors on the stationary assembly. If you don't get continuity on the latter, the issue is what I've mentioned and that can be fixed easily. Let us know what you find... |
Post# 239572 , Reply# 2   7/10/2013 at 04:25 (3,942 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Check the thermal fuse as well, sits around the main wire harness. I got a DOA one, and the fuse had blown its solder off. Quick re solder and good as new! |
Post# 239948 , Reply# 5   7/13/2013 at 04:06 (3,939 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
Their held together with lots of torx screws. Take the bag lid off and you will start to see some. Some may be hidden under the wheels |
