Thread Number: 20941
Has anyone done a motor "transplant"? |
Post# 234463 , Reply# 1   5/29/2013 at 13:29 (3,985 days old) by crock ()   |   | |
Your best bet is to find an electric motor repair shop near you. They can rewind the armarure and field stator and fix any orher issue you are having. Do a google search for "electric motor rewind or repair". |
Post# 234476 , Reply# 2   5/29/2013 at 14:57 (3,985 days old) by kenkart ()   |   | |
Put new Lamb motors in all kinds of old vacuums, Hoover tanks, Constellations, Lewyts ETC, GEs ,Sunbeams Apex Strato, would be next to impossible, just because how the motor is installed. |
Post# 234501 , Reply# 3   5/29/2013 at 19:07 (3,985 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
A word of advice....DO NOT try to modify the motor itself to make it fit & work properly in your Vorwerk!! Chances are pretty high you will wind up causing permanent damage to the motor that would be irreversible. Even if it could be modified, it's better to take it to a professional motor rebuilder or a vac shop technician who knows what they are doing, & it would be more cost effective to just buy a motor that doesn't need modifying in the first place.
However, having said that, it is very easy to modify mounting plates on the new motor, or use the existing mounting plate on the old motor to make it work & fit well. It may also be necessary to modify the plastic inside the motor compartment to make it work, especially if the new motor is slightly longer than the old one. One final word of advice....be VERY careful that the new motor doesn't draw a signifigant amount more amp's than the old one. On some vacuums, such as the Canadian Electrolux AP & 86/88/89 models, this can be an issue, as the motors in them were only 5 amps, & the maximum they can handle is 8 amps, or else you will fry the internal wiring, switch & cordwinder. Therefore, this limits what type of motors these units can handle. Good luck getting your Vorwerk working again....Rob |
