Thread Number: 20239
Kirby Heritage/Legend Series 13" Nozzle |
Post# 226742   4/5/2013 at 11:51 (4,053 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 226750 , Reply# 2   4/5/2013 at 12:36 (4,053 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
There is, of course, that extra nodule on the back side as to accommodate the Heritage/Legend series safety switch (the older versions of this nozzle casting for models 513 to D80 will not work on the Heritage/Legend series w/o modification.
I'd love to know what the part number is on the casting for the Heritage/Legend 13" nozzle... if ever there is one. I'd like to think it reads 140982. ~Ben This post was last edited 04/05/2013 at 13:05 |
Post# 226756 , Reply# 3   4/5/2013 at 13:08 (4,053 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Brad (IL-Kirby-Fan),
While Kirby may not have moved enough Heritage/Legend orders with the 13" head to justify a separate parts breakdown for it, they did, however, publish separate information for Heritage II models with the older Sani Em-Tor. It's the one marked "POCKET BAG WITH LARGE EMTOR." ~Ben |
Post# 226757 , Reply# 4   4/5/2013 at 13:18 (4,053 days old) by Electrolux137 (Los Angeles)   |   | |
Post# 226820 , Reply# 5   4/5/2013 at 18:52 (4,053 days old) by kirbyduh (Kentucky )   |   | |
So good to see you on vacuumland! Ben, I have 2 of the small nozzles. My first one has the heritage 2 turbo belt lifter on it and the number is 140062 |
Post# 226845 , Reply# 6   4/5/2013 at 19:41 (4,053 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
kirbyduh: Thank you for giving me the part # on its casting. I wonder how the same part # you found would still apply to the version of the nozzle, with the nodule that's there for the 134381 safety switch? I'd still like to wonder what the complete 13" Heritage nozzle part # is (entire nozzle plus brush roll)?
electrolux137: Welcome back, Charles! I'd reason to think the old-style single-row brush roll #1551 was still being used for the 13" Heritage nozzle, right? ~Ben |
Post# 226857 , Reply# 7   4/5/2013 at 20:38 (4,053 days old) by kirbyduh (Kentucky )   |   | |
There is a sticker with a number behind the bumper, would that be the number for the entire assembly? Both my small nozzles came with a multi row Brushroll. |
Post# 226859 , Reply# 8   4/5/2013 at 20:41 (4,053 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 226878 , Reply# 9   4/5/2013 at 21:51 (4,053 days old) by kirbyduh (Kentucky )   |   | |
The number on the sticker is 1351100311 |
Post# 228299 , Reply# 10   4/13/2013 at 22:59 (4,044 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 234947 , Reply# 11   6/2/2013 at 23:00 (3,994 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
According to Kirby through its official Facebook page, they say the complete nozzles (without brush roll) are part nos. 143382S (Heritage I), 143384S (Heritage II) and 143388S (Legend II).
The individual replacement parts are: 140182 - Nozzle bumper (1HD) (use 140483, cut to size) 140184 - Nozzle bumper (2HD) (use 140485, cut to size) 140188 - Nozzle bumper (LGII) (use 140488, cut to size) 140869 - Nozzle bumper rivet (all) 143179 - Air adjusting plate (early 1HD) 144081 - Belt lifter cap casting (1HD) 144084 - Belt lifter cap casting (2HD) 144088 - Belt lifter cap casting (LGII) 144181 - Belt lifter spring washer (all) 144281 - Belt lifter cap hook (all) (use 144291) 144681 - Belt lifter cap spring (all) 144781 - Belt lifter mounting screw (all) 145481 - Belt lifter bearing (all) 146381 - Belt lifter top label (1HD) 146384 - Belt lifter top label (2HD) 146388 - Belt lifter top label (LGII) 146681 - Instruction decal (1HD) 146684 - Instruction decal (2HD) 146688 - Instruction decal (LGII) 146781 - Belt lifter bottom label (1HD) 146784 - Belt lifter bottom label (2HD) 146788 - Belt lifter bottom label (LGII) 148282 - Quadra-Sweep brush roll (all) (use 500505) 154169 - Brush roll adjusting screw (all) 154456S - Rug plate with gasket (all) 1545 - Rug plate hinge rivet (all) 1547 - Rug plate hinge (all) 1548S - Rug plate gasket set (all) 301282 - Belt (all) (use 301291) ~Ben |
Post# 264621 , Reply# 12   1/24/2014 at 02:15 (3,759 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Brad (IL-Kirby-Fan), Lane (kirbyduh) and all,
The individual replacement parts (this time with corrected part numbers) for these 13" nozzles are: Model code: 1HD = Heritage H84 = Heritage 84 2HD = Heritage II LI = Heritage II Legend LII = Legend II 140869 - Nozzle bumper rivet (all) 143179 - Air adjusting plate (early 1HD) 143382S - Nozzle complete less brush (1HD) 143383S - Nozzle complete less brush (H84) 143384S - Nozzle complete less brush (2HD) 143387S - Nozzle complete less brush (LI) 143388S - Nozzle complete less brush (LII) 144081 - Belt lifter cap casting (1HD/H84) 144084 - Belt lifter cap casting (2HD/LI) 144088 - Belt lifter cap casting (LII) 144181 - Belt lifter spring washer (all) 144281 - Belt lifter cap hook (all) (use 144291) 144681 - Belt lifter cap spring (all) 144781 - Belt lifter mounting screw (all) 145481 - Belt lifter bearing (all) 146381 - Belt lifter top label (1HD/H84) 146384 - Belt lifter top label (2HD) 146387 - Belt lifter top label (LI) 146388 - Belt lifter top label (LII) 146681 - Instruction decal (1HD) (use 146684) 146684 - Instruction decal (2HD) 146781 - Belt lifter bottom label (1HD) 146783 - Belt lifter bottom label (H84) 146784 - Belt lifter bottom label (2HD) 146788 - Belt lifter bottom label (LII) 147982 - Nozzle bumper (1HD) (use 140483, cut to size) 147984 - Nozzle bumper (2HD) (use 140486, cut to size) 147988 - Nozzle bumper (LGII) (use 140488, cut to size) * 153471 - Brush bearing retainer (all) * 153571 - Brush bearing, bronze (all) * 1539 - Brush end cap, small (all) * 1540 - Brush end cap, large (all) 154169 - Brush roll adjusting screw (all) 154456S - Rug plate with gasket (all) 1545 - Rug plate hinge rivet (all) 1547 - Rug plate hinge (all) 1548S - Rug plate gasket set (all) * 155281 - Brush end cap sleeve, white (all) 159056 - Belt (all; factory installation) 301282 - Belt (all) (use 301291) 500505 - Quadra-Sweep brush roll (all) (NLA; procure NOS) * For brush rolls equipped with sleeve bearings and removable end caps. ~Ben |
Post# 298335 , Reply# 13   9/14/2014 at 04:30 (3,526 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Lane, and everybody,
Here is my Heritage II small head, courtesy of Mark D. Faryniak (marks_here). ~Ben |
Post# 298378 , Reply# 14   9/14/2014 at 16:21 (3,526 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
