Thread Number: 19593
Wessel Werk HEB160 Power Brush |
Post# 217825 , Reply# 1   2/6/2013 at 00:19 (4,097 days old) by kirbykid (Horseheads,New York 14845)   |   | |
Is it really that good? I've been thinking of getting one for my compact so I can do the stairs. How does it work with pet hair? |
Post# 217826 , Reply# 2   2/6/2013 at 00:19 (4,097 days old) by kirbykid (Horseheads,New York 14845)   |   | |
Will it fit the compact? |
Post# 217842 , Reply# 4   2/6/2013 at 05:57 (4,097 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Post# 219110 , Reply# 7   2/14/2013 at 07:09 (4,089 days old) by countryguy (Astorville, ON, Canada)   |   | |
I have the Wessel Werk HEB160 but I find that the electrical prongs are too short to work with my new black Rainbow. I have to hold the plug into the connection on the hose handle in order to have it make electrical contact. I already had the Wessel Werk prior to getting the Rainbow so that is why I did not purchase the Rainbowmate.
Gary |
Post# 219111 , Reply# 8   2/14/2013 at 07:26 (4,089 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
I have to wonder if you should try to spray something onto the new brushroll to make the bristles a bit stiffer. My thinking being that if the long bristles were stiffer, perhaps they would not wear down as quickly. Also, I would contact Wessell Werk & let them know this issue you are having, they may not be aware of this problem.
Good luck....Rob |
Post# 219150 , Reply# 10   2/14/2013 at 17:01 (4,089 days old) by floor-a-matic (somewhere)   |   | |
I had the HEB160 for a year, & I didn't put downward pressure; the brush works great without extra pressure. I think the culprit may be the carpet inside my car? The carpet inside the trunk is rough. |
Post# 220593 , Reply# 12   2/24/2013 at 08:06 (4,079 days old) by floor-a-matic (somewhere)   |   | |
Wessel Werk HEB160 (left) & TriStar MiniStar M101 (right) |
Post# 220594 , Reply# 13   2/24/2013 at 08:08 (4,079 days old) by floor-a-matic (somewhere)   |   | |
Both PNs are the same width |
Post# 220595 , Reply# 14   2/24/2013 at 08:10 (4,079 days old) by floor-a-matic (somewhere)   |   | |
Underside of both mini PNs |
Post# 220938 , Reply# 15   2/26/2013 at 22:04 (4,076 days old) by floor-a-matic (somewhere)   |   | |
Extension cord for using the HEB160 with a vacuum that does NOT have a PN receptacle. |
