Hello all. I need some help with my Kirby classic III. When I took it apart i put the machine back together and the headlight didn't work. If anyone can help me out I would greatly appreciate it. Thanks.
David
kirby505
Post# 217278 , Reply# 1   2/2/2013 at 16:42 (4,101 days old) by KirbyClassicIII(Milwaukie, Oregon)
Remove the bulb, see if the tip on the bulb looks a little burned? If it is, get a new bulb and look into the plastic housing to see if the tab in the center has any melted plastic around it, try lifting the tab a bit, being careful not to break it. Also, make sure the 2 wires are fully inserted into the connections on the light socket.
