Thread Number: 19406
Electrolux motor fan mystery, Part 1 |
Post# 215110 , Reply# 2   1/21/2013 at 13:37 (4,112 days old) by rlewis10 ()   |   | |
thank you Seth! |
Post# 215286 , Reply# 3   1/22/2013 at 09:55 (4,111 days old) by rugsucker (Elizabethton TN)   |   | |
Good info above.B might be for Diamond Jubilee(and late Silv).Hint-Remember opening of fan points toward bag that it will pull air through.On Elux is is possible to turn rear fan backwards and everything still fit as I learned the hard way in the Olympia days. |
Post# 281240 , Reply# 6   5/20/2014 at 19:11 (3,628 days old) by Paul (USA)   |   | |
So are all Electrolux (USA) motor fans interchangeable? |
Post# 281565 , Reply# 8   5/23/2014 at 13:45 (3,625 days old) by dysonman1 (the county)   |   | |
Post# 281595 , Reply# 10   5/23/2014 at 19:47 (3,625 days old) by tig21er (Indiana)   |   | |
found a slight error the fan for the E, and S were the same fans as the XXX and XLl. The Auto E on had the same fan.The early fans were 4 1/2" and the newer ones were 5". |
Post# 281609 , Reply# 11   5/23/2014 at 21:34 (3,625 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Post# 281622 , Reply# 12   5/23/2014 at 23:10 (3,625 days old) by tig21er (Indiana)   |   | |
can not sell genuine Electrolux motors. |
Post# 281639 , Reply# 13   5/24/2014 at 05:53 (3,625 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Here in Canada, you CAN take an Aerus Electrolux to your local vac shop & get a genuine Electrolux motor for it. All the major distribution companies....Hibbert, Tip Top Parts & JohnnyVac, can get Electro Motor motors. All 3 motors they offer- the double stage Discovery upright motor, double stage plastic body canister motor, & the single stage metal body motor are genuine Electro Motor motors, EXACTLY IDENTICAL to what Electrolux was using before they became Aerus & sold their motor manufacturing division, & started sourcing their motors from Johnson Electric.
Rob |
