Thread Number: 19400
Kirby assistance needed |
Post# 215016   1/20/2013 at 21:09 (4,113 days old) by isaiah (wyoming, MN)   |   | |
Just replaced bearings and brushes on my 562 and now the vac runs real slow. What did i do wrong? Safety switch? |
Post# 215019 , Reply# 1   1/20/2013 at 21:25 (4,113 days old) by kirbykid (Horseheads,New York 14845)   |   | |
Is it hard to turn the fan? Maybe you forgot to hook up part of the motor? |
Post# 215022 , Reply# 2   1/20/2013 at 21:30 (4,113 days old) by isaiah (wyoming, MN)   |   | |
the fan spins with ease |
Post# 215033 , Reply# 3   1/20/2013 at 23:21 (4,113 days old) by kirbykid (Horseheads,New York 14845)   |   | |
I haven't ever encountered something like that. I'm pretty sure that if part of the motor is disconected it won't work at all. Are the motor brushes seated properly? Id also try to clean out the safety switch and regular switch. |
Post# 215071 , Reply# 4   1/21/2013 at 09:01 (4,113 days old) by vacman1961 (North Babylon, New York)   |   | |
Could you have possibly cut a wire on the armature while you changed the rear bearing? Is it sparking excessively on the commutator? Is the rear bearing spring and washer sitting inside the housing or maybe it fell out and is shorting out something near the field winding or armature? I hope this helps. |
Post# 215321 , Reply# 5   1/22/2013 at 14:13 (4,112 days old) by vacman97 ()   |   | |
Did u clean the commutator, carbon can build up on it and cause poor contact. |
