Thread Number: 19396
My Lux 2100 died. |
Post# 214985 , Reply# 1   1/20/2013 at 17:06 (4,113 days old) by caligula (Wallingford, Connecticut)   |   | |
I have no idea why there's no power. As for the cord winder, if it won't retract, then the spring is sprung This needs professional repair. The spring is a strong steel coil, and razor sharp. Do not attempt to work with it, you could be baddly cut! The only thing I can think of is that the cord has been severed inside the winder.
Get it to a repair shop. |
Post# 214987 , Reply# 2   1/20/2013 at 17:07 (4,113 days old) by floor-a-matic (somewhere)   |   | |
Did the cord winder terminal(s) dislodge/break off? That might be the cause for the Lux to not operate & the cord winder jammed. |
Post# 214990 , Reply# 3   1/20/2013 at 17:34 (4,113 days old) by thevacuumman (Borger, TX)   |   | |
With the 2100, I would say just replace the cord reel I had the same problem with mine. |
Post# 215008 , Reply# 4   1/20/2013 at 19:58 (4,113 days old) by smith (North Carolina)   |   | |
Sounds like the cordwinder needs to be replaced to me as well. |
Post# 215058 , Reply# 5   1/21/2013 at 06:53 (4,112 days old) by kirbyguy (Columbia, MO)   |   | |
Thank you all for your replys. |
Post# 215289 , Reply# 7   1/22/2013 at 10:25 (4,111 days old) by collector2 (Moose Jaw, Sk)   |   | |
If you were getting a grinding sound chances are either the contacts have bent / broken, or the rings on the take up reel have broken loose. As you mention that the cord isnt rewinding I would suspect the latter. The cord breaking at the reel is also quite common. Either one is an easy fix. And dont be intimidated by the spring - it isnt a problem if you treat it with a bit of respect. I'm thinking that a broken piece of the reel may have jammed the spring too - not allowing it to retract.
The reel itself is about a $15 part but you can buy a complete cord reel assembly if you dont feel up to the repairs. Doug |
