Thread Number: 18706
Flush Mount Vacuum |
Post# 205840 , Reply# 3   11/4/2012 at 15:43 (4,191 days old) by eurekaprince (Montreal, Canada)   |   | |
Hey Joe...they seem to have a 230volt version for Europe! Here are the specs from the website:
Quick Specs •Only 9 1/2" wide x 17 1/2" high (29 9/16" for GarageVac's) x 4" deep. •5.5 foot long electric cord attached •400 air watts, 100" H20 water lift. •120 volt, 12amps, 50/60 hz, •230 volt, 6amps, 50/60 hz (Call for Pricing) •6 Year Warranty •MADE IN THE USA! |
Post# 205842 , Reply# 4   11/4/2012 at 15:58 (4,191 days old) by pr-21 (Middletown, OH)   |   | |
Mounted in my garage. You can get it with the stretch hose or a normal central vac hose. It has a lot of power. The stretch hose has a kick back like normal stretch hoses. I had them build me another stretch hose to couple onto the one I had. They were concerned at first, due to the fact that if I stretched both hoses to the max the airflow/suction would be greatly reduced. I told them I was not going to do this as I just wanted it not to have the kickback when vacuuming the inside of my car.
Anyway they made me one and it works great. I can go to the far end of my garage without stretching the hose at all, so no kick back. I also used it in my kitchen once, when I broke a light bulb. Picked it all up and I did not have to use one of my premium vacuums..... The bags will let you pack them pretty full without losing a lot of airflow/suction. The bags are on the expensive side....you also get a filter with each 5 pack of bags to go into the bottom of the bag chamber. There is almost no dust inside the bag compartment and I have had mine for over a year now. I also pick up leaves that blow into the garage and have not clogged the hose yet. PR-21 Bud Mattingly |
