Thread Number: 18504
Eureka Boss 1934 |
Post# 203410 , Reply# 2   10/10/2012 at 18:32 (4,216 days old) by joejoe83 ()   |   | |
Thanks man, how do I check to see if the carbons have went bad? Is thus nechanie from the 1980's? |
Post# 203416 , Reply# 3   10/10/2012 at 19:44 (4,216 days old) by mieles7 (TX)   |   | |
This vacuum is from the 1990s, but Eureka used that same deign for most of their uprights ever since the 50's. Here's the current version of that model.
CLICK HERE TO GO TO mieles7's LINK |
Post# 203423 , Reply# 5   10/10/2012 at 20:57 (4,216 days old) by KirbyUltimateG (Troy Ohio 45373 USA)   |   | |
Hello. Your vacuum cleaner is model number 2034. The part number for the motor is 54773. I hope this helps. CLICK HERE TO GO TO KirbyUltimateG's LINK |
Post# 203428 , Reply# 6   10/10/2012 at 22:39 (4,216 days old) by HooverCelebrity (Germany)   |   | |
Moved to contemporary forum |
Post# 203475 , Reply# 8   10/11/2012 at 15:19 (4,215 days old) by vacuumfreak (Ontario, Canada)   |   | |
Old Motor |
Post# 203476 , Reply# 9   10/11/2012 at 15:20 (4,215 days old) by vacuumfreak (Ontario, Canada)   |   | |
Newer Blender style motor. The old motor is called a "pancake style" motor based on its appearance. |
Post# 203477 , Reply# 10   10/11/2012 at 15:22 (4,215 days old) by vacuumfreak (Ontario, Canada)   |   | |
Lastly, here are my two Eureka's :-) Hope this helps! Good luck! They're great machines! Daniel :-) |
Post# 203487 , Reply# 11   10/11/2012 at 17:45 (4,215 days old) by joejoe83 ()   |   | |
Thanks everyone :) |
Post# 203499 , Reply# 12   10/11/2012 at 20:16 (4,215 days old) by vacuumfreak (Ontario, Canada)   |   | |
No problem! Let us know how you make out! :-) Daniel :-) |
Post# 203578 , Reply# 13   10/12/2012 at 16:03 (4,214 days old) by kirbykid63 (Wilmington Delaware)   |   | |
I had a sanitaire that did the same thing and it turned out to be a broken switch. |
Post# 203689 , Reply# 14   10/14/2012 at 09:32 (4,212 days old) by joejoe83 ()   |   | |
Maybe I should start with the switch, prior before it quit working I smelled a slight burning smell then it would not turn on again :( |
Post# 203697 , Reply# 15   10/14/2012 at 11:53 (4,212 days old) by vacuumfreak (Ontario, Canada)   |   | |
The motor might be burnt right out. If its not the switch I would just replace the whole motor. Just my opinion. Keep us posted :-) Daniel :-) |
Post# 203712 , Reply# 16   10/14/2012 at 12:54 (4,212 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 206781 , Reply# 17   11/15/2012 at 18:27 (4,180 days old) by 052334 ()   |   | |
I just peaked in to see what this site was about. The cooperation and generosity of the contributors to this thread has to be commended. |
