Thread Number: 18342
Filter Queen accessory power failure |
Post# 201522   9/23/2012 at 13:32 (4,232 days old) by troopersam (Perris)   |   | |
The accessory power outlet on my 360 has failed. For those that regularly perform repairs, is this a pretty simple problem to fix? Thanks in advance! |
Post# 201553 , Reply# 1   9/23/2012 at 21:17 (4,231 days old) by kirbykid63 (Wilmington Delaware)   |   | |
The filter queen is easy to disassemble,remove the screws under the handle and lift the dome and replace the socket its simple. |
Post# 201570 , Reply# 2   9/24/2012 at 07:13 (4,231 days old) by sbakerde (Millsboro, DE )   |   | |
Do you mean the outlet on the canister or the connection in the hose handle? If your canister outlet isn't working you may need to replace the PC Board. |
Post# 201888 , Reply# 3   9/26/2012 at 18:47 (4,229 days old) by troopersam (Perris)   |   | |
The outlet on the canister is correct. And replacing a PC board sounds a bit on the pricy side. |
