Thread Number: 18266
In the market for a steam mop,Or a floor washer... |
Post# 200601   9/13/2012 at 20:24 (4,242 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 200611 , Reply# 2   9/13/2012 at 21:00 (4,242 days old) by Blackheart (North Dakota)   |   | |
Post# 200627 , Reply# 3   9/13/2012 at 23:31 (4,242 days old) by Durango159 (State College, PA)   |   | |
I've never tried the Hoover Floormate but have heard great things about it. Also never tried a Haan but I'd be curious.
One of my clients has 2 steam mops a: Shark and an H20 Steam mop. The Shark is worthless. The pumping action for the steam, I find is virtually ineffective. Sometimes there is tons of steam and other times there is nothing. It smears the floor and just doesn't seem to accomplish anything. I've completely given up on it, I don't use it anymore, and in my mind it belongs in the dumpster. The H20 mop on the other hand produces tons of steam. It removes and cleans well. However I also find the floor too wet many occasions. If you let it sit on a stubborn spot too long, it can and will easily warp a laminate floor if you go over it too many times or let it sit on a spot. I blame a lot of this on the cloth cleaning head, it doesn't move across the floor unless its quite wet. However, this is my current experience with both of these products which I've been using for close to 2 years now, but I was not around when either was purchased new. Its possible brand new they both worked better!! The steam mops will find some dirt and push it around. I grab a rag and wipe up anything that the mop finds. I think most of what it finds was either stuck on the bottom of a rug, or on my shoes. I'm always sure to vacuum hard floors thoroughly with bare floor brush prior to steam mop. Don't sweep-- vacuum for steam mopping!! |
Post# 200661 , Reply# 4   9/14/2012 at 10:17 (4,241 days old) by jkbff (Dickinson, ND)   |   | |
Since the shop I work for sells Hoover, I tried out the hoover twin-tank steam mop in a pizzeria I work in part time... I really like the twin-tank. It works a lot better than the sponge mop the manager decided she wanted us to all use (dumb)... I sweep debris up, run the steam mop with the solution, then rinse the pad, and run it again on steam only. The pizzeria is in a hotel that had taken a room and put a pizza oven in it.. LOL.. So its the size of a hotel room, with ceramic flooring.. Works pretty well because the tiles have gradually turned white again and the grout has turned tan from black... Just my 2 cents.
Post# 200663 , Reply# 5   9/14/2012 at 10:36 (4,241 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Sadly its the opposite with me - I have lino, marble flooring and hard wood that is sealed - perfect examples for a steam mop. It has to be non-porous flooring for a start if you do choose cheaper steam mops - and I've had one for the last five years, replaced by the same model due to my own stupidity. I have tried carpet upright washers that have an attachment for hard floors, but they take too much time, often leave the floor too wet and impossible to do wearing just socks on my feet.
I also think its too much bulk and weight compared to sweeping around with a steam mop. Of course, what makes it better is the fact that I managed to get microfibre cloths for it rather than using the standard ones they came with as they're next to useless unless you spend more time letting the machine heat up and use more water than necessary. |
Post# 200701 , Reply# 6   9/14/2012 at 18:22 (4,241 days old) by Durango159 (State College, PA)   |   | |
So Sebo-Fan what model do you like/ recommend and what models have you had problems with!!
Joshua, I actually love sponge mops--but only the rectangular head ones with wringer on handle. You can put lots of elbow grease into them, and deep cleaning off the sponge in the mop water. Many floors need a good decent wet down, like linoleum and ceramic. When my water gets dirty I replace it. I like using Armstrong floor cleaner, it smells really good. Also Ajax lemon citrus and orange variety multi purpose cleaners found at Home Depot and Wal-Mart work really good. I don't like Pine Sol. Haven't received good cleaning results from them. Mr. Clean has a good line with Gain and the Orange scented disinfectant multipurpose does good. The other few lines from Mr. Clean I don't like. They are both with Febreeze--one is green and one is a Hawaiian pink, Also being on the business side I definitely see the desire to reduce costs and not go for extravagantly priced cleaning supplies. I've had many managers over the years that were quite reluctantly with replacing vacuum cleaners and/or upgrading some supplies. Everything is about saving costs in a business and to increase profit. |
Post# 200705 , Reply# 7   9/14/2012 at 18:44 (4,241 days old) by Floor-a-matic (somewhere)   |   | |
I use either a mop (like the one Durango159 has) or my Hoover Floor-A-Matic, it depends on how busy I am. Or I use the Rainbow SqueegeeMate, because I can switch from washrinse or mopdry vacuum. |
Post# 200752 , Reply# 9   9/15/2012 at 04:00 (4,240 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
There was a previous thread post on here already regarding washers and steam mops.
www.vacuumland.org/cgi-bin/TD/TD-...
There I discussed my own machine = a Hometek Light n Easy Elite. I still have it though and it still works after a few good years. I will be disappointed when it breaks because Hometek no longer sell that model any more and may have to seek out their Eco model instead, (previous machine design before this flatter one came out) which is just as good, if not slightly bulkier. The green Eco mop was also tested by Which last year and it got a thumbs up despite some cons.
Post# 200778 , Reply# 10   9/15/2012 at 09:02 (4,240 days old) by szymonrules (Philadelphia, PA )   |   | |
Post# 201305 , Reply# 11   9/20/2012 at 18:00 (4,235 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 296841 , Reply# 12   9/3/2014 at 11:38 (3,522 days old) by steammoplist ()   |   | |
HAAN Slim and Light SI-35R is the best You can find some reviews about this steam CLICK HERE TO GO TO steammoplist's LINK |
Post# 296848 , Reply# 13   9/3/2014 at 12:08 (3,522 days old) by cleaningbuff (Quincy, IL)   |   | |
Post# 296853 , Reply# 14   9/3/2014 at 12:30 (3,522 days old) by FantomFan (Rochester, New York)   |   | |
My grandmother's Regina floor scrubber is 50 plus years old, and still going. Our Shark Steam Mop lasted 4 years of LIGHT use, before it broke. I love my Hoover FloorMate. It gets stuff the Shark never even touched. It has a vacuum to clean up the floor before you do the deeper clean. Sorry Shark, you didn't create the idea of having a 2-in-1 machine!
Post# 296854 , Reply# 15   9/3/2014 at 12:33 (3,522 days old) by FantomFan (Rochester, New York)   |   | |
