Thread Number: 17313
Chinese Fantoms, including commercial |
Post# 186215 , Reply# 1   6/19/2012 at 01:14 (4,329 days old) by gmerkt (Edmonds WA)   |   | |
More Fantom FM 788 HG: |
Post# 186216 , Reply# 2   6/19/2012 at 01:15 (4,329 days old) by gmerkt (Edmonds WA)   |   | |
Switch area: |
Post# 186218 , Reply# 4   6/19/2012 at 01:19 (4,329 days old) by gmerkt (Edmonds WA)   |   | |
Parts donor machine Model FM 741 B. |
Post# 186344 , Reply# 7   6/19/2012 at 17:40 (4,329 days old) by floor-a-matic (somewhere)   |   | |
Did Sharp use Fantom's design to make the Light N Powerful? |
Post# 186380 , Reply# 8   6/19/2012 at 19:21 (4,329 days old) by FantomLightning (Ohio)   |   | |
I have no sold info on that... But it does look like a cross between a Fury and Wildcat but it all depends when the LNP came out. |
Post# 186382 , Reply# 9   6/19/2012 at 20:41 (4,329 days old) by director12 ()   |   | |
Seems like a strange machine. |
Post# 186422 , Reply# 11   6/20/2012 at 06:00 (4,328 days old) by gsheen (Cape Town South Africa)   |   | |
I had to laugh when I saw the fantom 788 commercial with that chrome stuck on the front, when I worked in vacuum design we often got sample machines from many chinese factory's , they would always send the domestic version and then a commercial version. Often the only difference between the two was a thicker cord on the commercial machine along with chrome sticker covering the front of the machine. Some how by pasting chrome all over the machine they thought it made the machine invincible. Gareth |
Post# 186439 , Reply# 12   6/20/2012 at 10:28 (4,328 days old) by director12 ()   |   | |
The Chinese Fantoms also were the Twister series, Thunderbolt, Falcon, Cyclonic handvac, and much more. |
Post# 186685 , Reply# 14   6/21/2012 at 17:24 (4,327 days old) by director12 ()   |   | |
$200 is not right for a commercially-rated vacuum. A commercial vacuum is better when it is made from the ground up, not from a household vacuum. |
Post# 186739 , Reply# 20   6/22/2012 at 09:22 (4,326 days old) by director12 ()   |   | |
Commercial products from China don't mean anything. If it's made in Germany, America, or Japan, it's better. |
Post# 186743 , Reply# 22   6/22/2012 at 09:35 (4,326 days old) by director12 ()   |   | |
Say Zach, what would your reaction be if you had the Dirthunter, after the fun you had with the Transformax? |
Post# 186796 , Reply# 24   6/23/2012 at 00:06 (4,325 days old) by director12 ()   |   | |
I'm not dealing with Euro-Pro products, let alone Sanyo. Fantom water-filtration devices are questionable. |
Post# 186798 , Reply# 25   6/23/2012 at 00:10 (4,325 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
I can verify for you FOR SURE the Fantom Twister FM740 WAS made by Sanyo, & this entire series of vacs are nothing more than rebadged Sanyo Dirt Hunter uprights. I remember about 2007 seeing on a website the Sanyo Dirt Hunter version of the Fantom Twister FM740....but the price for the Sanyo version was ASTRONOMICAL in comparison to the Fantom....$200 in Walmart for the Fantom Twister, $800 for the Sanyo Dirt Hunter.
I personally feel these Fantom Twister vacs have gotten a bad rap. Yes, I do agree that the other Euro-Pro Fantoms & Euro-Pro vacs used to have their issues with quality, but these Sanyo-made Fantoms are much better. Many people don't realize that these Fantom Twister's use the EXACT SAME motor the Sanyo Performax bagged uprights have inside them. And the Sanyo Performax was meant for DIRECT competition against Panasonic Performance Plus Platinum uprights, as the earlier versions had a metal brushroll & metal bottom plate. The motors on the Fantom Twister's & Sanyo Performaxes were HUGE & really do go a long time before dying. Yes, I have heard of the issue with the fuse, & there is also another issue with the Fantom Twister FM740....there is a small micro-plug & receptacle that connect power to the top & bottom halves of the vacuum. Over time, the plug & receptacle can disconnect & make the vacuum stop when pulling backwards, & make it run when going forward. Only way to correct it is to bypass the plug & receptacle, & hardwire all the wires together. Point I'm trying to make is, these are excellent value vacuums for what they sold for new. Rob |
Post# 186799 , Reply# 26   6/23/2012 at 00:26 (4,325 days old) by FantomLightning (Ohio)   |   | |
Thanks for confirming that Rob! I could've sworn I had seen people talking about it before but I wasn't sure. |
Post# 186818 , Reply# 27   6/23/2012 at 06:54 (4,325 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
You're absolutely correct, gmerkt. A lot of the Euro-whatevers are also sold in the UK under Morphy Richards (who strangely enough now seem to be churning out Shark based uprights under their Clarity branding) and also TTI Vax churned out a Dirt Devil model that was sold under Euro-Pro.
Also I have been in the cleaning business and it doesn't matter how a vacuum cleaner becomes commercial from a domestic model or commercial to domestic; it depends on how it is made and how much engineering is put into it to sustain long term use as well as long running time through daily use. This is why Karcher's own Sebo based uprights have some Sebo components built into them but then Karcher have this knack of using really cheap plastic to fill in the exterior parts that are left to question their durability when they break off in early use.
Bagless vacuums just don't work well in most cleaning industrial areas - health and safety/rules regarding the dumping of dust conflict with hygiene rules and thus, the bagged principle is the better way to go, amidst other rules of clinical preference to clean air in general.
Post# 186831 , Reply# 28   6/23/2012 at 08:51 (4,325 days old) by director12 ()   |   | |
I agree, bagged vacuums are the way to go. If Sanyo vacuums are not in production anymore, then I bet the Sanyo Fantoms are not. |
Post# 462351 , Reply# 30   4/16/2023 at 14:24 (376 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Congratulations! These vacuums have gotten pretty rare in the decades since you last posted. I keep an eye out for Fantoms all the time online and I personally have not seen one surface for at least 6 years or more. The design of the Fantom reminds me a lot of the Eureka Brushroll Clean with SuctionSeal (yes that is its real name), and I like the large panel of chrome trim.
