Thread Number: 17199
Question for Ben Edge (Kirby Classic III) |
Post# 184695   6/7/2012 at 14:59 (4,341 days old) by kloveland (Tulsa)   |   | |
Post# 184696 , Reply# 1   6/7/2012 at 15:02 (4,341 days old) by kloveland (Tulsa)   |   | |
Post# 184697 , Reply# 2   6/7/2012 at 15:06 (4,341 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 184710 , Reply# 3   6/7/2012 at 17:03 (4,341 days old) by kloveland (Tulsa)   |   | |
Post# 184713 , Reply# 4   6/7/2012 at 17:59 (4,341 days old) by JHGVac ()   |   | |
You apparently have the Blade Runner enhance function built into your eyeball.
Joe |
Post# 184719 , Reply# 5   6/7/2012 at 19:44 (4,341 days old) by kloveland (Tulsa)   |   | |
Post# 184720 , Reply# 6   6/7/2012 at 19:51 (4,341 days old) by kloveland (Tulsa)   |   | |
Some of you may cringe at the thought of this monstrosity. The metal fan may tear up the rubber on the end of the Elux hose. But it's a temporary solution. The Royal reminds of Kirby in so many ways. I do think Kirby had a better height adjustment system. The height adjustment knob at the rear is kind of awkward. But overall it seems light and easy to use. I’m glad to have one in my collection.
Post# 184735 , Reply# 7   6/7/2012 at 22:47 (4,340 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Kenny,
The real attachment set that you want is part #305. However, at the time of original production, these attachments were light blue if you stated them in the order invoice along with the vacuum itself. Otherwise, they'd be grey in color (as today). When this cleaner, the model 880, was replaced by models 886 and 887 in early 1987, the 886 was just the vacuum itself, while 887 also had the attachment kit included (light blue attachments). ~Ben |
Post# 184736 , Reply# 8   6/7/2012 at 22:55 (4,340 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Kenny,
I also want to say how the Rite-Hite height adjustment system works: you keep twisting the knob clockwise to lower the nozzle (counterclockwise to raise it), just enough so that the Adjust-O-Rite stub goes in toward the motor, to indicate the nozzle is at the correct height. Models 992 and 993 (the dark blue ones), and the burgundy 9000, all of which were introduced in early 1988 (and all of which initially had the white cord), have the "Au-Toe-Matic" foot-operated height adjustment. The lower pedal is used to lower the nozzle; the higher one is used to raise the nozzle. ~Ben |
Post# 184742 , Reply# 9   6/7/2012 at 23:32 (4,340 days old) by kloveland (Tulsa)   |   | |
My brush roll has brush stiffeners on it, probably a replacement. It really vibrates the carpet more so than other vacuum I own. Unfortunately, it really puts my Convertibles to shame. The vibration from the brush roll can be felt several inches from the machine. It really makes dirt, sand and grit bounce on the top of the carpet. It's a great cleaner. Compared the Royal with my Kenmore canister and the PowerMate also vibrates well (2 brush 1 beater combination). Not much else can compare. I haven't compared it to my Kirby G5 yet.
This post was last edited 06/08/2012 at 00:39 |
Post# 242657 , Reply# 10   7/28/2013 at 17:48 (3,925 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
