Thread Number: 15163
Kirby Tradition deep cleaning results |
Post# 160846   12/2/2011 at 00:56 (4,529 days old) by bnsd60m9200 (Akron OH)   |   | |
results after deep cleaning my 10 x 12 room and small walk in closet with my kirby tradition. there was such much stuff in the bag from this i had to shake it out 4 times to get everything out. also used miracle head before emptying as well. my carpet nap actually hasn't been this fluffy in a number of years....
Will Hemb Vintage Kirby and Hoover guru |
Post# 160851 , Reply# 1   12/2/2011 at 07:03 (4,529 days old) by Blackheart (North Dakota)   |   | |
Post# 160862 , Reply# 2   12/2/2011 at 12:11 (4,529 days old) by djtaylor (Salt Lake City, Utah)   |   | |
Post# 160872 , Reply# 3   12/2/2011 at 14:47 (4,529 days old) by kirbymodel2c (Nottingham, England)   |   | |
Post# 160878 , Reply# 4   12/2/2011 at 16:48 (4,528 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 160892 , Reply# 6   12/2/2011 at 20:19 (4,528 days old) by bnsd60m9200 (Akron OH)   |   | |
i hear a few of you mention your shake bags leak. i use two as daily drivers (tradition and classic omega) and i don't have dust leakage at all. are your bag springs tight? emptied after every use? washed if need be? if they are old enough to leak that badly and the above mentioned doesn't cure the issue, a new bag is in order. if they are super old machines i wouldn't use them as daily drivers if you want the original bag and it has fabric damage or a bag spring.
Will Vintage Kirby and Hoover guru |
Post# 160896 , Reply# 7   12/2/2011 at 20:42 (4,528 days old) by broomvac (N/A)   |   | |
Post# 160898 , Reply# 9   12/2/2011 at 20:49 (4,528 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 160901 , Reply# 10   12/2/2011 at 22:06 (4,528 days old) by JHGVac ()   |   | |
Hello Dave, What did you do to convert your Tradition to use the HEPA bags? Joe |
Post# 160902 , Reply# 11   12/2/2011 at 22:06 (4,528 days old) by bnsd60m9200 (Akron OH)   |   | |
oh ok.. that makes sense all. nice :) i like the dump bags better provided the bags are in good shape :) my trad has a new oem bag on it (its only a few months old) and is made out of the same fabric as the heritage style bags. it filters a TON better than say the omega bag. not that the omega bag is crap, but it lets a lot less air out on the trad bag.
Post# 160905 , Reply# 12   12/2/2011 at 23:10 (4,528 days old) by eurekastar (Amarillo, Texas)   |   | |
I did that to my Tradition. First, pop out the Tradition bag mounting collar from the Em-tor. Then all you need is a bag mounting collar from a Heritage. Use a 1/8 inch drill bit to drill holes in the Em-Tor flange so you can attach the bag mounting collar to it. On the one I had, the gasket was a little leaky, so I put a bead of silicone calk around it. You'll also need the wire re-enforced fill tube and bag adapter from an early G series Kirby. Just use a couple of zip ties on each end to attach. A very simple and straight forward conversion.
Post# 160906 , Reply# 13   12/2/2011 at 23:16 (4,528 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 160908 , Reply# 14   12/3/2011 at 01:34 (4,528 days old) by tolivac (Greenville,NC)   |   | |
"Leaking" Kirby dump bags--sure the leak isn't the bag-could be you need new emptor gaskets.On older machines esp-these can wear,then leak.Feltlike gasket on the Emptor lid. |
Post# 160971 , Reply# 16   12/3/2011 at 18:11 (4,527 days old) by bnsd60m9200 (Akron OH)   |   | |
oh guys, i didn't convert it to a bagged system. it's a new shake bag with the newer heritage bag style material. it still has a sani pocket. and yes emtor tray gasket replacement i something i do matter matter what on any sanu emtor kirby. it HAD an original bag system and removed the bag and tube assembly, bought a NEW oem shake bag for my trad. works wonderfully.
Will |
Post# 160990 , Reply# 17   12/3/2011 at 21:49 (4,527 days old) by eurekastar (Amarillo, Texas)   |   | |
