Thread Number: 14999
Oreck XL 9100 Help Please! |
Post# 159066 , Reply# 1   11/15/2011 at 11:31 (4,545 days old) by Oreck_XL (Brooklyn, New York 11211)   |   | |
Since, you mentioned you took it apart to clean it up I'm guessing you jarred some wires loose. Try fitting the bottom plate on and see if any wires are getting in the way. Also, make sure all the screws are out of the bottom plate when you are test fitting it back on the cleaner. An improperly aligned screw will cause the bottom plate to not fit back on right. Hope this helps.
- Hershel |
