Thread Number: 14538
maneuvering Kirbys |
Post# 153882 , Reply# 1   10/1/2011 at 16:20 (4,590 days old) by vinvac (Dubuque IA)   |   | |
Post# 153910 , Reply# 2   10/1/2011 at 23:02 (4,590 days old) by Sablekid ()   |   | |
Sometimes it helps to use the suction relief vent, but not all the time. Like said above, it depends. |
Post# 153921 , Reply# 3   10/2/2011 at 01:57 (4,590 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
The suction relief vent is designed to reduce suction, as desired, for use on lighter-weight throw rugs and other delicate carpets. Mostly you want to have the vent fully closed for full power; also, it should remain in the closed position when you empty the bag.
If you reduce suction by way of this vent, be sure to always have the headlight cap down against the nozzle. ~Ben |
Post# 153922 , Reply# 4   10/2/2011 at 02:10 (4,590 days old) by gsheen (Cape Town South Africa)   |   | |
Hey Joe
what lux and voorwerk models do you have , I have a few aswell?
When I was a youngster I used to build up my upper body strength buy using our legend 11, we had a large room with wooden flooring that a rug had been placed on with shortish cut pile. you needed all your strength to push the machine across the floor. saying that I will grab a pre g over any newer g any time , I find the g particularly the sentria cumbersome to use. I have two of them and must admit I hate them don't know why I bought them , trying to swap them for older models but in SA there are not many collectors :) |
Post# 153998 , Reply# 6   10/2/2011 at 19:38 (4,589 days old) by BrianKirbyClass (Eudora Kansas)   |   | |
Having the Kirby brush roll adjusted correctly on both sides of the Rug Nozzle(as to its bristle length, and the thickness of the carpet being cleaned), a new strong belt, and having the height of the rug nozzle set correctly is very important, or else the Kirby will be practically impossible to push on certain carpets.
Also a FOUR ROW brush roll installed in the Rug Nozzle will help tremendously in the pushing of the Kirby,,infact,by installing a 4 roll brush roll, brand new belt, having it adjusted on both ends to the correct height, and adjusting the rug nozzle correctly to the carpet being cleaned,,,the Kirby should all but pull itself along,,you should be able to push the Kirby with one finger,,easily. Even the heaviest Classic Omega or Tradition. Many times just cleaning the brush roll of any strings or anything wound around the brush, and installing a NEW BELT is all that is needed. Remember too that in order to adjust the height of the Rug Nozzle itself correctly, start with the Rug Nozzle all the way in the UP position, (the adjusting lever should be pushed all the way down). Turn on the Kirby and one click (step) at a time, SLOWLY lower the nozzle until a change of tone can be heard in the Kirby Motor. Now STOP. If the pushing and pulling of the Kirby at this level breaks the suction, lower the Rug Nozzle one more notch. If doing this makes the Kirby too hard to push,,the Brush Roll needs adjustment, and/or a new belt needs to be installed. Be sure to have a FOUR ROW brush roll and brand new belt installed in any older machine. |
Post# 154019 , Reply# 8   10/3/2011 at 00:57 (4,589 days old) by BrianKirbyClass (Eudora Kansas)   |   | |
Right on,,totally agree! Excellent points.
I was/am not a fan of the suction relief vent on the rug nozzle and always keep them closed. To me, the suction shouldnt need cutting down in the rug nozzle. Dont worry about the suction of the Kirby unless your motor sounds like its blown a fan blade, or its NOT what it should be. IF after all this adjusting, the Kirby is sticking ot the carpet or as what we used to say "Galloping" or jumping across the carpet when you push, pull,,the rug nozzle is TOO LOW,,or the pile of the carpet is extremely low. In that case then,,you DONT need to use the Kirby with the brush roll engaged,,turn the brush roll off by swinging the belt lifter around, put down the headlight hood, and vacuum the carpet that way,,or else, better yet, remove the Rug Nozzle and use the hose with the wands, coupler elbow and large rug nozzle attached. (Is what a Kirby salesman would tell a client) Or if you are a vacuum nut, go and get your Electrolux Model G, with PN that is not so agressive! haha |
Post# 156265 , Reply# 10   10/21/2011 at 14:08 (4,570 days old) by lunchboxsean ()   |   | |
Kirby Kick... That's hilarious... Seriously, I've never heard of carpet that thick. I've never heard of carpet one finger thick, though I do have fat hands. |
Post# 157815 , Reply# 12   11/2/2011 at 18:42 (4,558 days old) by truckerx (Palm Springs, CA)   |   | |
As I recall, according to Kirby, one lowers the rug head a click at a time until the vibration from the brush roll is audible THEN DOWN ONE ADDITIONAL CLICK. In theory, this is supposed to be the optimal setting, but with thick rugs, the rug head may have to be raised a bit until the struggle ends and some cleaning efficiency remains.
