Thread Number: 13976
Electrolux / Perfect / Miele Questions...
Post# 147986   8/20/2011 at 08:24 (4,632 days old) by danorob1 (Central New Jersey)
danorob1's profile picture
Hi All,
I have not posted in quite a while, but still follow every day…
I Have two questions…
1) Will the Electrolux Sidekick fit onto the stock Handle of the Perfect Power Team Canister Vacuum (Andrew – Are you still on the forum ? – I still have it and use it weekly !!! )
2)Does the stock Miele Turbo Brush fit the S7 7580 Swing Upright ? How does it perform with the uprights suction ? I have seen people saying it will fit, and some say it will not...
I purchased the S7 Swing from my Local Miele Diamond Dealer – Great Vacuum – Handles like a dream… I purchased the Vacuum, Bare Floor Tool, and 2 boxes of bags for $639.00 out the door… He also included the Flexible crevice tool and the Micro Cleaning Kit which he said came with the S7 Swing since it was a Diamond Dealer Only Model…
Love The Steel Blue/Grey finish…
Thanks for the help,
Dan
Post# 148004 , Reply# 1   8/20/2011 at 10:57 (4,632 days old) by Elux89 ()
Answer to question #1
Yes, the electrolux sidekick will fit onto the handle of the perfect power team canister. BUT, be careful. The electrical contacts on the perfect hose may not line up "perfectly" with the sidekick. They could be out by say 1/32 of an inch, in which case the sidekick won't run. You might have to wiggle/bend the rubber piece on the hand grip so it will slide right into the sidekick. BUT, if you have to bend the rubber contact on the hand grip, too much force can cause it to snap and break. The perfect is a good machine, but the fit and finish are somewhat lacking.
Hope this helps.
Question #2, sorry, never tried fitting the turbo brush on a S7
Post# 148010 , Reply# 2   8/20/2011 at 12:06 (4,632 days old) by joshdonnell ()
miele s7
i have the turbo brush for my miele , the turbo brush works both the cansiters and the uprights.
