Thread Number: 13950
Moulinex Major |
Post# 147638   8/18/2011 at 07:53 (4,635 days old) by vacbear58 (Sutton In Ashfield & London)   |   | |
Post# 147639 , Reply# 1   8/18/2011 at 07:56 (4,635 days old) by vacbear58 (Sutton In Ashfield & London)   |   | |
Post# 147640 , Reply# 2   8/18/2011 at 07:58 (4,635 days old) by vacbear58 (Sutton In Ashfield & London)   |   | |
Post# 147641 , Reply# 3   8/18/2011 at 08:01 (4,635 days old) by vacbear58 (Sutton In Ashfield & London)   |   | |
This is what I know as a dirty fan cleaner, the hose simply inserts in here, behind the brushroll, with a piece down the front to cut the suction off from the brushroll. Unfortunatly I dont have tools for this cleaner
This post was last edited 08/18/2011 at 08:16 |
Post# 147643 , Reply# 4   8/18/2011 at 08:15 (4,635 days old) by vacbear58 (Sutton In Ashfield & London)   |   | |
I always feel that you dont get a really good sweeping performance unless there are agitators as well as brush strips. As a cleaner this is not bad, a bit noisy perhaps, and its fairly easy to use. When I first got it I thought the performance was not very good as the suction seemed very low. As a mini-meet a few weeks ago the "spa elves" agreed and took it apart. They found that a childs sock had got right through the fan chamber intact but had then got stuck in the hose going to the bag. There are about 15 screws holding the plate on the bottom of the cleaner
Although it was quite common in catalogues of the time, you dont see many of these around although there was a soft bag (and slightly later) version on ebay a few weeks ago. Al |
Post# 147672 , Reply# 5   8/18/2011 at 12:21 (4,634 days old) by kirbymodel2c (Nottingham, England)   |   | |
Hi, Here are my Moulinex vacuum cleaners. The hard and soft bagged versions both from the early 80s. I've found them to be good cleaners and run quite and smooth.
I do have the hose and floor head for the major. The suction on the major is quite good. I do need to get a new light bulb for the Major tho... There a strange bulb, 45 volt... I pictured them with the hard and soft bagged Goblin commanders which was also out in the 80s. Hope you like the pic:o) James:o) |
Post# 147683 , Reply# 7   8/18/2011 at 15:01 (4,634 days old) by kirbymodel2c (Nottingham, England)   |   | |
Umm I know moulinex made vacs earlier than the 80s.
But dirty fan, hard bag vacs don't suffer those kind of problems normaly. I am aware that sometimes on the Hoover starlight doors use to weaken over time. But most of this design was perfectly fine and used by quite a few company's. Overall a nice design of vacs:o) James:o) |
Post# 148545 , Reply# 8   8/24/2011 at 06:08 (4,629 days old) by gsheen (Cape Town South Africa)   |   | |
