Thread Number: 13009
Dysons dc23 and dc22 |
Post# 138758 , Reply# 1   6/6/2011 at 20:21 (4,707 days old) by eurekaprince (Montreal, Canada)   |   | |
Brandon,
Though I'm sure the Dyson Motorhead is a reliable machine, the telescopic wand can not be disconnected from the hose. This makes the hose very bulky to use for anything but floor and carpet cleaning. So I would recommend the turbine-head over the Motorhead model. Since the turbine head does not require any wiring in the wand or hose, I think you can remove the wand so that you are left with a small hose handle for cleaning in small/tight spaces like most other canister vacs. You should explain this difference to your mom, because if she wants to use the vac to clean bookshelves or car interiors, the Motorhead is very inconvenient to use for those purposes. Just something to think about... Eurekaprince Brian :-) |
Post# 138802 , Reply# 3   6/6/2011 at 22:05 (4,706 days old) by eurekaprince (Montreal, Canada)   |   | |
Brandon - that's a great idea to test them out first.
I think the reason that the Motorhead appears to have a longer hose is that a large part of it has to disappear into the wand when you extend it for carpet and floor cleaning. As you stretch out the telescopic wand, the hose stays connected to the lower part and the wand kind of stretches "over" the next few feet of hose. You'll get what I mean when you try it out. If you stretch out the telescopic wand on both the Turbinehead and the Motorhead, you'll probably see that the length of hose remaining between the handle and the canister are the same length. Let us know what you decide!! :-) |
Post# 138814 , Reply# 4   6/6/2011 at 22:25 (4,706 days old) by piano_god (British Columbia, Canada)   |   | |
The DC22 is the smaller of the two and uses the DDM, where as the DC23 is larger and uses a conventional motor. As you mentioned, the DC22 Motorhead has its controls on the handle. Its Motorhead is also much smaller and less agressive than the one provided on the DC23 Motorhead.
Keep in mind that the hose retracts into the wands when they are in their extended position on the Motorhead models, so the length of hose when the wand is fully extended is reduced. The aluminum used on the wand of DC23 Motorhead scratches very easily. Infact, mine is all scratched just from using its telescopic feature. As mentioned, the Motorhead wand setup can make certain tasks quite difficult, like dusting, as it feels like you're using a baseball bat to complete the task. Definitely give both models a thorough "test drive" in the store... |
Post# 138817 , Reply# 5   6/6/2011 at 22:31 (4,706 days old) by vacman117 (Chicago, IL)   |   | |
I had a DC23 Animal for a while and it was one heck of a vacuum! The suction was tremendous and the turbine tool was most definitely agressive enough. The only reason I took it back was because it was way to impractical for my size of house. Otherwise I would have kept it.
If you do go with a turbine head, go with the Animal. It comes with Dyson's AMAZING mini turbo nozzle and the articulating floor tool which is probably the best bare floor I've ever used. Chase |
Post# 138863 , Reply# 8   6/7/2011 at 06:59 (4,706 days old) by eurekaprince (Montreal, Canada)   |   | |
You're welcome Brandon!
You know, it really comes down to whether you will use this vac for carpet cleaning or not. If it is primarily for carpet cleaning, and you want a Dyson, why not get an upright since the hose and tools on the Dyson uprights are easier to use than on their power nozzle canisters? If you will use it mostly for carpets, get the Dyson DC28 Animal upright: Consumer Reports has given it a "recommended" tag - it's "very good" for carpet cleaning, "excellent" for bare floor cleaning and the airflow through the hose for tool use was rated "very good". When you remove the handle and hose for above-the-floor cleaning, the Dyson upright almost turns into a canister vac anyhow. If you need this vac to clean non-carpeted surfaces mostly, then get one of the Dyson canisters that does not have a power nozzle - the hose/wand set-up on those is easier to use. Let us know what happens!!!! :-) |
Post# 138892 , Reply# 9   6/7/2011 at 15:36 (4,706 days old) by piano_god (British Columbia, Canada)   |   | |
This is my opinion of the DC23 Motorhead only. I have not used the DC23 Turbinehead version.
Good points: - Strong suction. - Root cylcone + Core seperator works really well. The washable filter remains very clean. Bad points: - Upper gasket between the machine and the bin squeals when you pick it up during vacuuming. - Hose is side mounted, which makes it awkward to pull the canister behind you. - A bit loud. - Runs quite hot. - Motorhead has a very high-pitched, shrill sound due to its motor and gear system. - Hose kinks easily as it's made thinner due to the electrical cord being run through the centre of the hose. - Aluminum wand scratches due to the action of extending and compressing. - Wand cannot be removed from the hose. - Messy to empty. IMHO, there are better canisters available for the money. The DC23 Motorhead is one of the very few new machines that I do regret purchasing. It spends most of its time in its box. As Brian mentioned, I too would recommend a Dyson upright over their Motorhead canister. |
Post# 138893 , Reply# 10   6/7/2011 at 15:54 (4,706 days old) by Brandon_W_T ()   |   | |
My mom really wants a canister. We looked at miele but we can't afford any of them. Will look into the turbine head. |
Post# 138897 , Reply# 11   6/7/2011 at 17:01 (4,706 days old) by kirbyloverdan (Egg Harbor Twp . NJ aka HOOVERLOVERDAN ❤️)   |   | |
Post# 138901 , Reply# 12   6/7/2011 at 17:26 (4,706 days old) by eurekaprince (Montreal, Canada)   |   | |
Best deal on the market now for a power nozzle canister (if you don't mind bagged), is the good old fashioned Panasonic power nozzle canister Model MC-CG902 - it does everything well and has all the tools you need. In Canada, they are selling for CAD450, and at J&R in New York, you can get it for $200!!! See the link below.....this canister will give you much less grief and higher performance than the Dyson canisters. This is the Panasonic version of the well-known Sears Kenmore Progressive that is no longer available at Sears.
Here's the link to J&R CLICK HERE TO GO TO eurekaprince's LINK |
Post# 138906 , Reply# 13   6/7/2011 at 17:55 (4,706 days old) by vacman117 (Chicago, IL)   |   | |
Run the Hoover Windtunnel Cyclonic Canister in green, or the Platinum, across your mom. I have the green version and they are truly amazing vacuums. They also have one of the best deep cleaning power nozzles I have ever used. The power nozzle uses TRUE Windtunnel Technology, the tools are conveniently located on the handle and it is almost impossible to have them fall off. All of the wheels are also soft touch, which gives a pleasant sound to the ears when it rolls across hard floors.
Just a thought. Chase |
Post# 138943 , Reply# 16   6/7/2011 at 23:21 (4,705 days old) by HooverCelebrity (Germany)   |   | |
It was a very merry Christmas that year! LoL
Here was my main reasoning for not getting the DC23 Motorhead:
CLICK HERE TO GO TO HooverCelebrity's LINK |
Post# 138964 , Reply# 17   6/8/2011 at 07:36 (4,705 days old) by mark40511 (Lexington, KY)   |   | |
