Thread Number: 11448
Patriot and Air Storm Vacuums? |
Post# 123677 , Reply# 1   2/1/2011 at 18:54 (4,844 days old) by Kirbylux77 (London, Ontario, Canada)   |   | |
The motor LOOKS the same as a Tri-Star Ametek motor, but my local vac shop guy says the motors in the Patriot/Airstorm burn out quicker & last about as long as a Filter Queen Ametek motor, not as long as the Tri-Star. He says that there isn't as much copper wiring used to make the field armature on the motors, that's why.
However, one could install a Tri-Star CXL motor in the Patriot when the motor burns out, or even a 12-amp Domel motor, as both these are the same size as the Patriot's Ametek motor. And of course, would be just as powerful. I personally prefer the Patriot over the Tri-Star, as they have a better HEPA filter on the exhaust, & have the best filtration of all the Tri-Star wannabees. Rob. PS- Anyone who has a Tri-Star & wants the Medik-Aire HEPA filter from the Patriot, can just call the company, claim they have a Patriot & buy one & put it on the Tri-Star. I have done that on mine & it fits & works perfectly fine. |
Post# 123687 , Reply# 3   2/1/2011 at 19:36 (4,844 days old) by kirbyvertibles (Independence, KS)   |   | |
Post# 123690 , Reply# 5   2/1/2011 at 19:54 (4,844 days old) by eurekastar (Amarillo, Texas)   |   | |
It's hard to beat a Tristar CXL. I think it's the best canister vacuum around. It's powerful and filters very well. The Tristar also has a very simple straightforward design, making it easy to work on. I've heard some people say the Eureka built power nozzle is clunky, but I like it. I have a Eureka VGII brush roll in mine, and it cleans like a beast! I also have an Airstorm. As I recall, it has a slightly higher amperage motor. It's also an excellent vacuum.
Post# 123707 , Reply# 6   2/1/2011 at 21:59 (4,844 days old) by kirbykid63 (Wilmington Delaware)   |   | |
Last week I found a miracle mate platinum series at my local goodwill store for a great price.The original power nozzle was cracked on the bottom so I am using a eureka world vac power nozzle and I like the performance very much. |
Post# 123712 , Reply# 8   2/1/2011 at 22:26 (4,844 days old) by kubvan1 ()   |   | |
I guess the answer to my previous question is that Eureka made the CXL power nozzles! I guess I assumed differently as the fancy metal top threw me off! Cheers, Doug |
Post# 123726 , Reply# 9   2/2/2011 at 00:11 (4,844 days old) by Kirbylux77 (London, Ontario, Canada)   |   | |
But it's achilles heel is the fact that it doesn't have a HEPA filter on the exhaust. All that it has it the Microfilter attachment that fits onto the motor, same as the Tri-Star's pre-motor filter cap. Also, the Patriot & Miracle Mate also has the advantage, over all these Tri-Star wannabees, is that they place the bag at an angle, which helps the vacuum retain some of its suction a little longer. And when you consider that the Patriot is just as powerful & they are selling it with the same powerhead as the Vortech Force, the Wessell EBK 340.....well I guess I would personally take the Patriot.
Also, the Miracle Mate may be a nice vacuum, with a good Sebo ET-C L-shaped commercial powerhead & just as much suction as the Patriot, but it is MUCH heavier, & not as easy to lug around as either the earlier Tri-Stars or Patriot. Rob |
Post# 123786 , Reply# 13   2/2/2011 at 13:47 (4,843 days old) by Kirbylux77 (London, Ontario, Canada)   |   | |
@Richard/kirbykid63: Well, I am glad to hear my advice was of some help to you. As far as generic Miracle Mate bags, I know I have seen generic ones being sold on Ebay a while ago....so just keep your eyes peeled. Or, ask your local vac dealer to enquire about them with his local parts distributor. I am sure he would appreciate it, actually, if he could get generics to sell at a lower cost to his customers.
However, if you are picking up fine dirt, I would just stick to using Tri-Star bags with a Miracle Mate bag top, as I suggested. In my area, I find I pick up lots of sand & fine grit, & it clogs easily, so it's really easy to just take the bag outside & dump the contents outside & reuse the bag a couple of times. Thats why I started using Tri-Star bags....I found the Miracle Mate bags had too much filtration, & of course got frustrated with having to throw out expensive bags with hardly any dirt in them. I imagine you would also have this problem if you used the micro-lined Tri-Star bags, as the micro-liner would just cling onto the fine dust. @David/twocvbloke: Yes, you could get the HEPA filter dome for your Tri-Star, but I would just buy the Patriot's Medik-Aire HEPA filter from them & stick it on your Tri-Star. I presently use the HEPA filter dome on my Miracle Mate, as there is no other way to do it, & that's the ONLY reason I use them. On my Miracle Mate (which is an earlier model, before they put the bag on an angle), the Patriot's HEPA filter simply won't fit into the exhaust port- the slot on the filter's pipe won't work with the pin on the Miracle Mate's exhaust port & it won't stay in place when the vacuum is turned on. You really don't get much HEPA filter paper in the filter itself, & the filters cost anywhere from $15-$20 CDN, depending on which shop you go to, & the manufacturer suggests replacing every 6 months. The Patriot's HEPA filter, when bought direct from Schoettler Research & Engineering, is $200 US dollars. However, the manufacturer suggests changing once every 3 years, so that breaks down to $66.66 per year, compared to $40 per year changing the HEPA filter domes. Think of it this way....you are paying about the same cost per year if you owned a Miele & were changing the HEPA filter once a year, if you use the Patriot's filter. The other thing to consider, is that the Patriot's HEPA filter is MASSIVE- my Tri-Star looks like it has a balloon stuck onto it! There's NO WAY the HEPA filter domes would outfilter the Patriot's HEPA filter, even if they were changed more frequently, due to the amount of filtering media the Patriot's filter has. As a matter of fact, the filter is so big, I would be willing to bet if one made sure the bags were changed when necessary & kept the foam filter dome clean, that most households could actually get 5 years out of each filter. Also, the Patriot's HEPA filter is a Certified HEPA, something the HEPA filter domes can't claim.... You are wise not to use the Filter Fresh filtration system Tri-Star makes for them, though, as they clog rather quickly & makes the vacuum lose a lot of it's power. I know you don't like the idea of using a clunky filter on the exhaust, but I would give it a bit of thought. Rob BTW- As I was finishing this post, I figured out that if you use the Patriot's HEPA filter for 5 years, it works out to $40 per year, so it would break even with the yearly cost of the HEPA filter domes. |
